Jumping Tach only when freezing temps outside
Old Jan 17, 2016 | 04:12 AM
Alyssared80's Avatar
Default Jumping Tach only when freezing temps outside
Got a 93 prelude. Remote start works fine and Tach is fine when first drive. Have to drive interstate partly to work. When I get off, the first stoplight I stop at my Tach is reving up almost 1000 rpms up and down. Kinda feel a pull when I slow down to take a turn as well.
What is causing this? Like I said, it only happens when its really cold outside. It was -1 degrees this morning.
Thank you for any info.
Old Jan 18, 2016 | 06:40 AM
Flr Power's Avatar
Default Re: Jumping Tach only when freezing temps outside
You could have a dirty Idle Air Control valve that freezes on the highway and when you slow down enough to engage the idle circuit, the frozen valve has trouble moving.
The throttle body can also ice up and prevent the throttle plate from properly closing and causing high idle.
Old Jan 18, 2016 | 09:57 AM
kp's Avatar
kp
The tach itself is malfunctioning? Or your engine is revving?
The throttle body has it's own coolant line so this doesn't happen.
Old Jan 18, 2016 | 01:19 PM
The engine is revving up as well.
Old Jan 19, 2016 | 05:59 AM
Flr Power's Avatar
It can still happen under the right conditions. It's not because you have never seen it that it is not possible.
vLad11591
Mar 12, 2009 08:15 PM
AccordEX1991
Mar 11, 2007 01:16 PM
quicksliver
May 28, 2005 11:20 AM
Tyree
Sep 3, 2004 06:32 PM
KeithsDAteg
Aug 31, 2004 12:01 PM
