Catch Can for B20/Vtec Turbo
What is the best way to install a catch can for my B20/Vtec turbo? I'm confused from what I've researched some folks said that is best to have routed to the back of the block and others to the valve cover. Can somebody clear this up with a diagram or pics? Thanks
The back of the block would be the easiest, unless you are down to weld some fittings to your valve cover.
I'm running an OBD2 b18b1 (no black box), which is the same as the b20. These are the fittings I used:
Acura Honda Catch Can Block Adapters Plug PCV B18 B16 B20 LS GSR SI Fittings | eBay
These are actually OEM honda fittings, forgot the part number. Just buy some good quality PCV hose, a baffled catch can, and you're good.
you're welcome
you're welcome
DrGrEeNtHuMb
Jul 30, 2009 04:30 AM
