1999 Civic DX Coupe Slow Build
Old Jan 8, 2016 | 06:42 PM
[RVL]Honda's Avatar
Default 1999 Civic DX Coupe Slow Build
First time recording a slow build, so bear with me as I don't know all the in and outs to posting.
Old Jan 8, 2016 | 06:43 PM
[RVL]Honda's Avatar
Default Re: 1999 Civic DX Coupe Slow Build
I picked this car up a few months back and barely had a chance to work on it.
Old Jan 8, 2016 | 07:55 PM
NotARaCist's Avatar
I never narc'd on nobody!
It's all good, we all started somewhere. just remember that this is the tech section, and try to keep it tech. You definitely have a hell of a lot of work ahead of you, though.
Old Jan 8, 2016 | 08:31 PM
eghatch9295's Avatar
Stancetard Hate Monger
lots of work indeed. that front end is all sorts of tweaked. the invalid who painted it didnt do you any favors, either
Old Jan 9, 2016 | 08:54 AM
tony_2018's Avatar
Fish Twig
Yup, first thing I noticed too. The front end. But yeah there are a couple of slow builds going on so don't worry about it too much. Not to mention slow builds that haven't been updated. Make a note of all the work that needs to be done and write down what you want to prioritize first and go from there.
Old Jan 11, 2016 | 02:46 PM
[RVL]Honda's Avatar
Looking at my torn OEM steering wheel. I talked to a friend with a wrecked RSX and asked if could get his spare steering wheel. He purchased another steering wheel to fix up his car, but decided to total it instead. I searched in the thread and found a DIY from Confidence for this swap.
Thread: rsx or ep civic steering wheel into EK airbag mod - Honda-Tech
I didn't have time to go to the junk yard , so I cut my OEM airbag clip to use for this wiring.
Old Jan 11, 2016 | 07:15 PM
[RVL]Honda's Avatar
Yes, the front was hit and the radiator bracket was a little bent too. Let me try to get a shot of it for you guys.
Old Jan 11, 2016 | 07:16 PM
[RVL]Honda's Avatar
I'll try to keep the updates going.
Old Jan 19, 2016 | 04:51 PM
[RVL]Honda's Avatar
Here's a picture of my broken radiator support. Do you guys think it repairable or it needs to be replaced by a new one?
Old Jan 19, 2016 | 05:06 PM
[RVL]Honda's Avatar
Here a picture with the RSX steering wheel install. The feeling is way better. It's thicker and the leather still feels new. Thanks to our fellow H-T Confidence DIY swap.
Old Jan 19, 2016 | 05:08 PM
[RVL]Honda's Avatar
I wonder why it didn't show on the last post.
Old Feb 19, 2016 | 07:01 PM
[RVL]Honda's Avatar
I got tired of looking at the Big O Tach on the side. My friend didn't give me an answer on his RSX type S Cluster, so I went and picked up an EX cluster from a 99 civic. All but 1 plug didn't fit. The green socket and the orange plug was a little off, so I filed down one side to make it fit. Then snap it went in.
Old Feb 19, 2016 | 07:09 PM
[RVL]Honda's Avatar
I turn my engine on to test the RPM and see if the temp was working. Everything seem fine. I even drove it around to see if the mileage was working properly. Then a check engine light turned on. I hope it the cluster that did this or did an CEL really did appear. I got borrow my brother's scanner and see if it throws a code.
Old Feb 19, 2016 | 08:05 PM
NotARaCist's Avatar
Or just jump the service connector and pull the blink code...
Old Feb 21, 2016 | 06:24 PM
[RVL]Honda's Avatar
Thanks NotaRaCist I already got my brother's scanner will do a scan tomorrow.
Old Feb 23, 2016 | 04:22 PM
[RVL]Honda's Avatar
I scanned my car and got P0138. Its my O2 circuit high voltage bank 1 sensor 2. Does anyone know, if this is the O2 sensor after the Cat? People said just to replace it. I also remove the aftermarket tach on the side. I'll take a pic and post it tonight.
Old Feb 23, 2016 | 04:30 PM
NotARaCist's Avatar
Yes, that's the sensor after the cat.
Old Feb 23, 2016 | 06:28 PM
[RVL]Honda's Avatar
Cool. Thanks bro.
Old Feb 27, 2016 | 10:37 AM
[RVL]Honda's Avatar
I did a reset on the ECU and later that evening the CEL popped back on. I guess its time to change it out.
Old Feb 27, 2016 | 10:39 AM
[RVL]Honda's Avatar
I started to hear some noises in the passenger front wheel when i run over something. It seems like a bushing problem. I went to remove the front wheel and found out my Upper control is different than my 96 EX.
Old Feb 27, 2016 | 10:41 AM
[RVL]Honda's Avatar
Does anyone know if the 99 DX UCA is a better design than the 96 EX? There does seem to be a problem with both, but since I have the part and if the 96 EX is better why not change it out.
Old Feb 27, 2016 | 12:41 PM
NotARaCist's Avatar
That first one is not a stock upper control arm.
Old Mar 27, 2016 | 10:03 PM
[RVL]Honda's Avatar
Finally got around and ordered the O2 sensor downstream meaning after the cat. I went with denso 234-4098.
Old Apr 25, 2016 | 08:06 PM
[RVL]Honda's Avatar
Borrowed my cousins O2 sensor removal tool,but the 3/8 socket hole couldn't be reached because of the shift linkage. I ended using a adjustable wrench and got it out. I then re-installed the Denso O2 sensor with anti seize lube. The Denso was a better fit length wise than the Bosch that I replaced.
Old Apr 25, 2016 | 08:08 PM
[RVL]Honda's Avatar
I also got a chance to replace my broken wheel stud in the rear driver side. I replaced all four wheel stud with ARP. The grade 8 bolts looks great.
