do itrs come with rear lower tie bars?
Old Nov 6, 2002 | 12:14 PM
[HrZn]4life's Avatar
Default do itrs come with rear lower tie bars?
hey guys...i'm planning to buy my friend a present and was wondering if itrs come stock with a rear lower tie bar already?? tia
Old Nov 6, 2002 | 12:15 PM
Chris N's Avatar
Default Re: do itrs come with rear lower tie bars? ([HrZn]4life)
No. There's a stiffener down there, but no lower tie bar.
Old Nov 6, 2002 | 12:16 PM
Default Re: do itrs come with rear lower tie bars? (1107)
thanks...
Chris N's Avatar
Rock on.
Old Nov 6, 2002 | 11:34 PM
Ch33se's Avatar
New User
what? a "stiffener?" what the hell...i might be dodohead but isnt that a rear lower tie bar? the gray steel bar?
Old Nov 6, 2002 | 11:36 PM
J_Edwards's Avatar
Default Re: do itrs come with rear lower tie bars? (Ch33se)
Yes and no....it is a stiffener becuase it doesn't actually make contact with the suspension mounts like the lower tie bar does. Technically it just reinforces the frame which the suspension is mounted to.
Old Nov 7, 2002 | 03:57 AM
Willard's Avatar
Old Nov 7, 2002 | 07:46 AM
Chris N's Avatar
It's not a tie bar. I don't know exactly what it is called, but I know what it isn't.
Chris - who wonders why someone would call themself a dodohead.
Old Nov 7, 2002 | 08:00 AM
Nate B's Avatar
It's a stiffy, not a tie bar. I have a tie bar and a stiffy, it's fun to kick the *** end out
Old Nov 7, 2002 | 08:13 AM
-Whitey-'s Avatar
Default Re: do itrs come with rear lower tie bars? (TypeR#1111)
will the stiffy fit on other cars? like an eg?
Old Nov 7, 2002 | 08:16 AM
Nate B's Avatar
Default Re: do itrs come with rear lower tie bars? (B16A EH2)
Negative ghost rider, but you can probably make a custom one y0
Dave-ROR's Avatar
if you make and weld on some brackets, it would. but you could instead just weld a bar there.
the subframe on the ITR is different, so it will not just bolt up if that's what you meant.
Old Nov 7, 2002 | 08:19 AM
Chris N's Avatar
What Dave said.
Just get a larger diameter sway bar or upper strut bar. Tie bars are the blizzle, they don't really do anything compared to a sway bar, or even a strut bar.
Old Nov 7, 2002 | 08:26 AM
Dave-ROR's Avatar
you mean the blizzle blizzle
integ233
Oct 7, 2006 11:54 AM
sohcvtec1995
29
Apr 24, 2004 06:16 PM
RUBZERK
Mar 25, 2004 10:00 AM
non vtec
Nov 15, 2002 10:42 PM
Suave99
Sep 3, 2002 07:09 AM
