Honda Accord limp mode?
Old Jan 1, 2016 | 03:03 PM
KingJeremy2315's Avatar
Default Honda Accord limp mode?
hello I drive a Honda Accord 1999 speed and today on my way home the car wouldn't past 4 rpm. Did some research to realize this process is called Limp mode. The cel is on, gonna get codes read tomorrow... What should I check for to go about getting this running better ? Any common issues to cause this ? Anyone experience ? What fixed your issue? Anything helps. Car still drivable and idles fine alittle high when cold but lowers down when warn. Car has 287,000 on the clock.
Old Jan 2, 2016 | 03:52 AM
poorman212's Avatar
Default Re: Honda Accord limp mode?
Get the code(s) and post them...the actual code number(s) and not someones description of the code.
Without the code(s)........
Old Jan 2, 2016 | 09:09 AM
MAD_MIKE's Avatar
MM Gruppe B
^This.
Code descriptions can vary wildly from incorrect to generically defined, including the descriptions given by a code reader.
Also multiple codes do not mean all systems are in fault. But will pinpoint to the most likely issue.
rmiv1985
Jun 27, 2019 04:10 AM
champainwagon
Mar 27, 2019 01:07 PM
JeffWashington
Dec 12, 2016 10:34 AM
tknep
Nov 2, 2016 05:00 AM
southmech
Aug 16, 2010 05:15 PM
