quick ? im working on the car right now!
Old Nov 6, 2002 | 11:14 AM
TypRice's Avatar
Default ECU help ! please!
how different is the 1994 civic ex ecu and the 1993 civic SI hatch ecu?
i know in 1995 the ecu changed a few pins,
please help!
[Modified by TypRice, 2:15 PM 11/6/2002]
[Modified by TypRice, 2:20 PM 11/6/2002]
Old Nov 6, 2002 | 11:32 AM
CivicTuneR95's Avatar
Default Re: ECU help ! please! (TypRice)
plug and play bro
Old Nov 6, 2002 | 11:45 AM
TypRice's Avatar
Default Re: ECU help ! please! (CivicTuneR95)
im trying but my check engine light came on
Old Nov 6, 2002 | 11:49 AM
ejprimo's Avatar
i believe that the 93 si ecu isnt vtec..please correct if wrong.
Old Nov 6, 2002 | 11:51 AM
CivicEx95's Avatar
Default Re: ECU help ! please! (ejprimo)
same engine so therefore they use the same ecu
Old Nov 6, 2002 | 11:53 AM
LshatchTurbo's Avatar
New User
Default Re: ECU help ! please! (CivicEx95)
if your getting CEL, try reseting the ECU.
fOmaNPu's Avatar
All 5th gen Si's were VTEC, and all 92 Civics are wired for VTEC. I don't see why you'd be getting a light, what code are you throwing?
Old Nov 6, 2002 | 11:59 AM
BackSideSA's Avatar
Default Re: ECU help ! please! (fOmaNPu)
EX to Si....if i'm not wrong...but they are the same engine.
Old Nov 6, 2002 | 12:01 PM
Kamin's Avatar
SI and EX are the same motor.
Old Nov 6, 2002 | 01:23 PM
JDMvtecDRAGSTA's Avatar
theyre the same ecu (p28) if the check engnine light came on, them one of the pins are fucked on the ecu that throws the cel
Old Nov 6, 2002 | 01:58 PM
B_CRUZ!'s Avatar
make sure you don't have a AUTO p28.
Old Nov 6, 2002 | 02:00 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: ECU help ! please! (B_Cruz)
Yeah because if you do then you'll get an automatic tranny code light.
Old Nov 6, 2002 | 02:13 PM
TypRice's Avatar
im throwing the crank angle senser i changed the distributer and still the same thing...yes the distributer works fine i stole it from my buddys motor!
here is the brake down...
car: 1990 civic hatch
engine: 1995 civic ex
engine harness: 1994 ex
ecu: I was using the 94 ecu but my friend confinscated it!
so now the 93 si ecu...i was running ...for about 2 weeks, then i put the car in the garage for a few days then when i came back for it... here we go the problem started!
oh yea i ckecked the risistance in the wires from the ecu harness to the dis. ind its fine!
should i try the 94 ecu again?
All 5th gen Si's were VTEC, and all 92 Civics are wired for VTEC. I don't see why you'd be getting a light, what code are you throwing?[/QUOTE]
Old Nov 6, 2002 | 02:22 PM
B_CRUZ!'s Avatar
crank angle sensor? obd1's have that?
Old Nov 7, 2002 | 03:35 PM
TypRice's Avatar
thats what the ECU is throwing!?
jfields06
Dec 27, 2008 06:42 AM
sannay562
Jun 11, 2008 07:07 PM
turbod16y8
Dec 16, 2002 02:20 PM
