Need help: so close to getting trans out
So I'm trying to change the clutch on my 90 si. You guys have been a great help so far. I took a few days off and now I'm back.
I'm pretty sure I have it down to the last bolt but no matter how hard I wail on it with my air gun, it won't budge.
Are there any work a rounds?
Thanks. You guys rule. I can see how this would go way better if I had worked on Hondas before. But oh well. I'm 48.9% there.
pulling my trans for the first time, i had the same issue. instead i pulled the bolt attatching the bracket to the bushing, then removed the bolt from the bracket once the trans was out with WD-40, P-Blaster, and a long handled ratchet. also just a note, the transmission will NOT come off with the starter attached. that had me hung up well over an hour before i figured that out my first time
If you are stuggling with the transmission just remember if everything is loose it should pop right out
Don't go banging and prying on it as you can damage the soft aluminum casing.
arielb1
Dec 18, 2019 11:39 AM
EF Two
12
Apr 1, 2003 09:32 PM
