FS : Left over parts, cheap price, Garage sale - ngo
Old Dec 23, 2015 | 05:44 PM
hondastreet's Avatar
Default FS : Left over parts, cheap price, Garage sale - ngo
FS: left over parts, cheap price
PRICE REVISED Febuary 25th, 2016 - Shipping is included
FREE SHIPPING ANY WHERE
and no paypal cost will be added
I'm from Montreal, Canada
$ 700.00 Skunk2 Stage 3 V3 Camshaft - brand new in box
$ 400.00 Skunk2 Stage 3 V3 Camshaft - barelly used, one casting default
$ 600.00 Ferrea Roller bleu version - used, but like new
$ 400.00 Injectors Dynamics 1000cc
$ 500.00 new price 300 k20 Catcam Camshaft with exhaust cam gear #2501913 (265/256 duration, 13mm/12mm lift) no sharp edge for better fatigue duration life, they are for high rev.
$ 450.00 new price 400 PRC ECU no K-pro
$ 450.00 new price 270 SKUNK2 K-series Throttle Body 74mm - black edition - no sensor
$ 400.00 new price 300 K20a Type R throttle body, oem spec, no sensors
$ 400.00 new price 350 10.2:1 Wiseco, Brand New, never started for k24 with k20 head
$ 350.00 new price 300 Spring from Tein N1 20kg/mm 24kg/mm (1120lbs/in - 1343lbs/in) - hard stuff
$ 250.00 Catback 2.5'' custom with Resonator and CTR muffler for ek9 with k20a
$ 200.00 new price 180 K20a PRC Type R intake manifold
$ 180.00 AutoMeter pyrometer (2 fois)
$ 100.00 AutoMeter Boost
$ 80.00 AutoMeter Fuel Pressure
$ 80.00 AutoMeter water temperature
$ 160.00 new price 120 k-tuned traction bar with Rad Brackets for Traction Bars
(does not comes with the stabilizer tie bars)
$ 150.00 new price 100 k20a Type R clutch and disc
$ 100.00 new price 70 WILWOOD Ultralite 11’’ dia. per 0.81’’ thick – mostly new
$ 100.00 new price 50 Scorpion inlet MP90 eaton magnason supercharge
$ 80.00 DC2 Lower Control Arm with Energy Bushing 1997-2001, may fit on others model
$ 50.00 k24a timing chain cover (dirty) - now at $40
$ 25.00 K20a Type R tensionner
$ 80.00 WISECO 88mm 10.2:1 – one piston damaged (set of 4)
$ 60.00 Toyota MR2 2001+ custom holding bracket for electric power steering
$ 60.00 JDM Civic Type R city light - both side
$ 60.00 OEM CTR Honda civic type R 96-00 side marker
$ 50.00 k24 crank shaft pulley
$ 50.00 Water temperature shock proof Marshall
$ 40.00 Unorthodox racing crank pulley
$ 25.00 AEM pulley Thru Power for Power Steering PS k20
$ 36.00 BEAKS reinforcement adapter for sway bar - 4 pieces
$ 30.00 MEZIERE fitting – 12an O-ring 1 1/4’’
$ 30.00 12'' fan - BN
$ 25.00 K20a type R Tensionneur
$ 20.00 k20a type R Solenoid vtec sensor (located on the timing chain cover) VTC
$ 15.00 Front camber arm bushing civic eg, ek, dc, da, ef - Energy bushing BN
$ 15.00 Tie rod and ball joint bushing civic eg, ek, dc, da, ef - Energy bushing BN
$ 10.00 AEM water methanol hose
$ 10.00 Several 2.5’’ or Clamp or coupling (price by unit)
$ 10.00 K070500 or k060547 or k060485 serpentine belt
$ 10.00 custom oil baffle for aluminium oil pan
$ 5.00 oil cap
$ 4.00 Vibrant performance weld on – 1/4 NPT and 3/8 NPT
All parts
k070500, k060547, k060485
WISECO 88MM 10.2:1 - NEW
SIDE MOUNT SPARCO
SCORPION INLET FOR MP90 supercharge, eaton, magnason
Water temperature Marshall
oil cap
96-00 CTR side marker, PRC ECU k20a R, weld-on 1/4 npt
Spring from Tein N1 20kg/mm 24kg/mm 1120lbs/in 1343lbs/in
oil baffle custom for aluminium k20a oil pan
Aluminium crank pulley
K20a Manifold Type R
AutoMeter pyrometer
Autometer Boost
AutoMeter Water temperature
k24 timing chain and Cover valve is SOLD
k20a Catcam camshaft
LCA integra type R - 1997 - 2001, may fit on other model
Wilwood rotor replacement 11’’x.81’’ bolt pattern 6*6.625
MR2 electric power steering pump holding bracket - $60
City light - $60
Meziere Fitting - $40/pair
Beaks - $36
12'' fan - $30
Energy Bushing - front ball joint, tie-rod end - $15
Energy bushing - front upper arm - $15
K24 water thermostat housing - $10
3'' elbow
3'' coupling
Several piping, clamps, coupling 2.5'' – $10 / each
Buld light for Fog Light $5 - Qty 2
Vibrant performance wield on - $4/each
Old Dec 27, 2015 | 10:11 AM
Default Re: FS : Left over parts, cheap price, Garage sale - ngo
engine support sold
valve cover sold
water housing sold
revised price from Dec 27th, 2015
Old Dec 27, 2015 | 11:49 AM
santeg1992's Avatar
10 Year Member
Interested in traction bar 775-412-2701
Old Dec 29, 2015 | 05:00 AM
LSD sold
vtec solenoid sold
water housing sold
K20a Type R Rocker arm and holders SOLD
Traction bar picture (NO TIE BARS INCLUDED)
VTC SOLD
DAMAGED CIVIC SI 2008 SOLD
Old Dec 29, 2015 | 10:50 AM
D15miniek's Avatar
I got a buddy who would buy some of this he isnt a member of the forum is there a way u can message me some contact info so i can get yall in touch
Old Dec 29, 2015 | 10:53 AM
^^ txt msg 514 249 five zero zero six
Old Dec 29, 2015 | 10:55 AM
D15miniek's Avatar
Awesome thnx
Old Dec 30, 2015 | 01:19 PM
LSD shipped
Water houssing shipped
VTEC solenoid shipped
Engine support shipped
cover valve type R shipped
I have a crazy deal on :
K20a Type R complete head
k20 Catcam Camshaft ***
PRC ECU no K-pro
10.2:1 Wiseco for k24 with k20 head
SKUNK2 K-series intake Manifold ported to 74mm
just offer me a price, these parts must go.
Old Feb 12, 2016 | 07:21 AM
NEW PRICE UPDATED (FEB 12, 2016) FOR THOSE FOLLOWING ITEM
TYPE R OIL PUMP
TYPE R OIL PAN
CATCAM CAMSHAFT
K-TUNED TRACTION BAR
TYPE R CLUTCH
WILWOOD ROTORS
all of them have been reduced
Old Mar 25, 2016 | 07:12 AM
k20a type R camshaft sold
oil pan sold
oil pump sold
price updated
hondastreet
Apr 15, 2016 07:13 AM
