FS : camshaft, head, k24a block guard, SC MP90, Injectors, ECU
FS: left over parts, cheap price
PRICE REVISED April 12th, 2016 - Shipping is included
FREE SHIPPING ANY WHERE IN USA AND CANADA
and no paypal cost will be added
I'm from Montreal, Canada
or txt 514 249 five00six
$ 2000.00 K20a Head with Ferrea OS intake valves, Ferrea Spring, TK head Porting, refresh done, dyno pull and have been removed
$ 2000.00 K24a8 with oil squirter, block guard, eagle rods, CP piston 11.5:1, bore 88mm - new
$ 1700.00 Supercharge MP90 w/o aftercooler
$ 2250.00 Supercharge MP90 w/ aftercooler (SC kit) - no water pump
$ 525.00 Skunk2 Stage 3 V3 Camshaft - brand new in box
$ 380.00 Skunk2 Stage 3 V3 Camshaft - barelly used, one casting default, run great
$ 600.00 Ferrea Roller blue version - like new
$ 450.00 new price 400 PRC ECU no K-pro
$ 400.00 new price 300 K20a Type R throttle body, oem spec, no sensors
$ 380.00 Injector Dynamics 1000cc
$ 350.00 Spring from Tein N1 20kg/mm 24kg/mm (1120lbs/in - 1343lbs/in) - hard stuff
$ 250.00 Catback 2.5'' custom with Resonator and CTR muffler for ek9 with k20a
$ 200.00 new price 180 K20a PRC Type R intake manifold
$ 180.00 AutoMeter pyrometer (2 fois)
$ 160.00 new price 140 k-tuned traction bar with Rad Brackets for Traction Bars
(does not comes with the stabilizer tie bars)
$ 150.00 k20a Type R clutch and disc
$ 100.00 WILWOOD Ultralite 11’’ dia. per 0.81’’ thick – mostly new
$ 100.00 Scorpion inlet MP90 supercharge eaton magnason
$ 100.00 AutoMeter Boost
$ 80.00 AutoMeter Fuel Pressure
$ 80.00 AutoMeter water temperature
$ 80.00 WISECO 88mm 10.2:1 – one piston damaged (set of 4)
$ 50.00 k24a timing chain cover (dirty)
$ 60.00 Toyota MR2 2001+ custom holding bracket for electric power steering
$ 60.00 OEM CTR Honda civic type R 96-00 side marker
$ 60.00 Hybrid Racing hoses k20z3 swap (k-swap)
$ 50.00 k24 crank shaft pulley
$ 50.00 Water temperature shock proof Marshall
$ 50.00 Sparco Side mount
$ 40.00 Unorthodox racing crank pulley
$ 36.00 BEAKS reinforcement adapter for sway bar - 4 pieces
$ 30.00 JDM Civic Type R city light - both side - no buld
$ 30.00 MEZIERE fitting – 12an O-ring 1 1/4’’
$ 30.00 12'' fan - BN
$ 25.00 AEM Thru Power Pulley Power Steeting PS K20
$ 25.00 K20a Type R tensionner
$ 25.00 K20a type R Tensionneur
$ 20.00 k20a type R Solenoid valve sensor (located on the timing chain cover) VTC
$ 15.00 Tie rod and ball joint bushing civic eg, ek, dc, da, ef - Energy bushing BN
$ 10.00 AEM water methanol hose
$ 10.00 Several 2.5’’ or Clamp or coupling (price by unit)
$ 10.00 K070500 or k060547 or k060485
$ 10.00 custom oil baffle for aluminium oil pan
$ 5.00 oil cap
$ 4.00 Vibrant performance weld on – 1/4 NPT and 3/8 NPT
All parts
Defect on it :
Hybrid racing hoses k20z3 swap
k070500, k060547, k060485 serpentine belt
SIDE MOUNT SPARCO
SCORPION INLET FOR MP90 magnason eaton
Water temperature Marshall
oil cap
96-00 CTR side marker, PRC ECU k20a R, weld-on 1/4 npt
Spring from Tein N1 20kg/mm 24kg/mm 1120lbs/in 1343lbs/in
oil baffle custom for aluminium k20a oil pan
Aluminium crank pulley
K20a Manifold Type R
Autometer Boost
AutoMeter Water temperature
k24 timing chain, VALVE COVER SOLD
Wilwood rotor replacement 11’’x.81’’ bolt pattern 6*6.625
City light - but with no buld
Meziere Fitting - $40/pair
Beaks - $36
12'' fan - $30
Energy Bushing - front ball joint, tie-rod end - $15
Energy bushing - front upper arm - $15
K24 water thermostat housing - $10
3'' elbow
3'' coupling
Several piping, clamps, coupling 2.5'' – $10 / each
Buld light for Fog Light $5 - Qty 2
Vibrant performance wield on - $4/each
Skunk2 k20 k24 cam gear - used
MR2 Pump bracket of EK / DC not painted
ID 1000 cc
AEM Pulley Thru Power
Ferrea stuff
SC MP90
^^ without fuel rail
^^ without TB
T. bar
unopen box : as it is
$ 5.00 oil cap
All parts
Defect on it :
SIDE MOUNT SPARCO
oil cap
Autometer Boost
Beaks - $36
12'' fan - $30
3'' elbow
3'' coupling
ID 1000 cc
Ferrea stuff
SC MP90
^^ without TB
T. bar
hondastreet
03-08-2016 11:59 AM
hondastreet
08-03-2015 05:17 PM
hondastreet
11-17-2013 04:39 PM
