91 ef hatch
You convert the car to OBD1, use a OBD0 to OBD1 ECU jumper harness, buy a vtec subharness if the pigtails provided with the jumper harness are not long enough to reach the corresponding sensors. Use the engine harness that came with the car and cut/extend wires that don't reach on the F20B. Buy a OBDO to OBD1 distributor conversion harness or wire it yourself. You may also need to use a resistor box for the fuel injectors (make sure the ecu is programed for independence / saturated). And use a wiring diagram online for the resistor box mod.
I think that's it for the wiring...
not trying to be a dick, but have you researched this at all? You're asking questions that would be answered with the slightest bit of research.
While I feel pretty comfortable saying, "if you are asking this stuff, you shouldn't be doing the swap". I will give you this advice....buy a Rywire harness and save yourself the trouble.
My very first post answered everything to make it run. If the harness is fucked buy another MPFI harness and start at with what I said. It will be wired correctly then. I wouldn't drag this thread out anymore or this people are going to start flaming you.
