FI E/M HOOD FUSE 44 KEEPS BLOWING OUT on Civic 1997
Old Dec 21, 2015 | 10:25 AM
samirsamir's Avatar
Icon5 FI E/M HOOD FUSE 44 KEEPS BLOWING OUT on Civic 1997
I have Honda Civic LX 1997 i recently have bad battery so i changed and after i instllaed the new one my fi e/m fuse 15a under hood keep's blow out soon as i turn my keys in ignnation to start the car..
can someone help me please.. thanks!
SAME
Old Dec 21, 2015 | 11:54 AM
Former User's Avatar
Default re: FI E/M HOOD FUSE 44 KEEPS BLOWING OUT on Civic 1997
Bone stock 97 Civic?
Is it fuse 44?
Old Dec 21, 2015 | 12:09 PM
samirsamir's Avatar
yes it is!
I have issue with battery the other day the battery light come on so i decid to took negative line off the battery to check for altenator if is bad. when i did that i saw couple sparks and car shut down .... i try the start the car but buttery was tottaly gone so i bought new battery and installed and since then i cant start the car because i found that time that my FIE/M fuse was bud and is keeping blowing up soon as i turn my keys..
Old Dec 21, 2015 | 12:12 PM
If you unplug connector C101, does fuse 44 stop blowing?
Old Dec 21, 2015 | 12:24 PM
samirsamir's Avatar
where is the connector C101??? maybe is on right side of the engine by the windshild wiper motor ????
i try that one and fuse stay good (did not blow) ..
this connector ???
Old Dec 21, 2015 | 12:41 PM
Plug C101 back in.
Unplug all 4 fuel injectors and the IACV? Does the fuse blow with key in ON(II)??
Old Dec 21, 2015 | 01:00 PM
samirsamir's Avatar
I unplug all four injectors but I can't find, actually I don't know where is the plug for IACV????
Old Dec 21, 2015 | 01:09 PM
Old Dec 21, 2015 | 01:38 PM
samirsamir's Avatar
I'm sorry, but I'm not sure what I need to disconnect, this IACV Valve plug in this picture??
Old Dec 21, 2015 | 01:40 PM
1. Unplug the electrical connectors for all 4 fuel injectors and the IACV.
2. Test whether fuse 44 still blows.
Old Dec 21, 2015 | 01:49 PM
samirsamir's Avatar
Ok I I step out for the moment I will try. Soon as I come back thank you
Old Dec 21, 2015 | 03:20 PM
samirsamir's Avatar
I disconnect all 4 injectors but in this picture I still can not find IACV plugin.
Can you explain me little bit more where is it
Old Dec 21, 2015 | 03:29 PM
The IACV is attached to the throttle body. Study the diagram I posted.
The IACV connector has 3 wires. You've found the IACV when you locate the connector with the 3 wire colors shown below.
Old Dec 21, 2015 | 03:56 PM
samirsamir's Avatar
. Ok I will look for it in a minute thank you
Old Dec 21, 2015 | 04:52 PM
samirsamir's Avatar
fuse 44 still blows ...
Old Dec 22, 2015 | 05:53 AM
Remove the cap from junction connector C130.
Does fuse 44 still blow?
Old Dec 22, 2015 | 06:28 AM
If removing the C130 cap prevents fuse 44 from blowing, then do the same test for junction connector C116.
Old Dec 22, 2015 | 07:05 AM
samirsamir's Avatar
Should I plug back in the electrical connectors for all 4 fuel injectors and the IACV before I proceed with this to new test's ,???
Old Dec 22, 2015 | 09:09 AM
samirsamir's Avatar
I pluged back in all four injectors and the IACV plug. Then I unplug junction connector C130 and the FUSE 44 didn't blow.
Should I now plug back in Connector C130 and disconnect junction connector C116 to see if FUSE 44 doesn't blow or does blow ???????????????
Old Dec 22, 2015 | 12:53 PM
Yes
Old Dec 24, 2015 | 08:42 AM
samirsamir's Avatar
yeah I did that a minute ago and a fuse stays good
Old Dec 24, 2015 | 08:43 AM
samirsamir's Avatar
I hope that I'm hearing from pretty soon to see what I need to do next ... Thanks for everything
Old Dec 24, 2015 | 08:52 AM
The tests that you've done so far have isolated the electrical short to one of the 5 Yel/Blk wires that runs from connector C116 to either fuel injector 1, 2, 3, or 4 or the IACV (see circuit diagram). With the cap removed from C116, test each of those five wires for continuity to body ground using a multimeter. The wire with continuity to body ground has the short that is blowing fuse 44. Replace that wire or repair the short and the problem will be fixed.
Old Dec 24, 2015 | 09:32 AM
samirsamir's Avatar
So I want to make sure I understand what I need to do,,,,, so I need from my multimeter put negative (black wire) on body ground and positive (red wire) from multimeter put on connector c116 actually on each of those 5 black and yellow wires coming from connector c116 . To check for continuity???
This is the multimeter that I have is this going to work?
Old Dec 24, 2015 | 01:25 PM
Multimeter is set correctly.
The testing may be more easily done from the 4 injector connectors and the IACV connector with C116 uncapped.
