b16a1 with ITR cams with or with out Adjustable Cam Gears
Old Dec 21, 2015 | 05:06 AM
gabrielsousa's Avatar
Default b16a1 with ITR cams with or with out Adjustable Cam Gears
b16a1 with ITR cams, use oem/stock cam gear or Adjustable Cam Gears ?
opinions ?
Old Dec 22, 2015 | 07:37 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: b16a1 with ITR cams with or with out Adjustable Cam Gears
If the cylinder head isn't milled, and the block is still stock deck height... cam gears will not be necessary.
Old Dec 22, 2015 | 07:54 AM
block is stock, cylinder is stock, piston is stock.
so i dont need Adjustable Cam Gears ?
i can use stock/oem cam gear ?
thanks
Old Dec 22, 2015 | 09:35 AM
.Manny.'s Avatar
Touching My Member
Are you going to have the car tuned?
Old Dec 22, 2015 | 02:51 PM
i have neptuneRTP and wideaband, i will tune fuel map,
can i use stock ignition map ?
Old Dec 28, 2015 | 08:03 AM
BLU CIVIC's Avatar
Track Advocate
Yeah, you're good. I just hope you changed your valve springs
Old Dec 28, 2015 | 08:04 AM
yes, i will change.
but i will not change on rpm, the cut will be on 8400
Old Dec 28, 2015 | 08:10 AM
BLU CIVIC's Avatar
Track Advocate
Yeah, I'd leave it the same. The only time I had my rev limiter changed is when I'm making power higher than stock.
Old Dec 28, 2015 | 10:48 AM
Ayrexxx's Avatar
If you are running a stock ECU I would probably stick with stock
but if you are tuning the car get some adjustable ones you can change to tune with
Old Dec 28, 2015 | 01:24 PM
i'm running p30 with neptuneRTP and wideband
Old Jan 4, 2016 | 08:28 AM
i will not lose torque with oem/stock cam gear ?
eortizr
Aug 16, 2005 06:36 PM
shrug
Oct 30, 2004 08:05 PM
hondamanwill
May 29, 2003 08:15 AM
insnimprtguy
Jul 17, 2002 02:11 PM
teg92
Sep 26, 2001 01:33 PM
