need help with injector part number
Old Nov 6, 2002 | 10:06 AM
eviltwin's Avatar
Default need help with injector part number
i wanted to get some prelude injectors for my type r. i know some of them have a 340 flow rate. i was wondering if anyone can help me get the oem part number of the injectors i would need for my R.
Old Nov 6, 2002 | 11:28 AM
Asahi's Avatar
Default Re: need help with injector part number (eviltwin)
I was under the impression they were all 290 which is from what I have seen 21% bigger than stock. Anyone else know more?
What Prelude were the 340's supposed ot have come out of?
Also You need OBD2 injectors I believe or there becomes a wiring problem. Have I made this up? Anyone?
Old Nov 6, 2002 | 11:30 AM
sgT's Avatar
sgT
Default Re: need help with injector part number (Asahi)
97+ h22a injectors are 290cc and are bolt in plugs and all.
pre97 h22a were 340-350cc and are PEAK HOLD and use a different style plug.
Austin's Avatar
'92-96 are the 340(not exactly sure)
'97+ are the 290cc/min...also the '95+ NSX(pretty sure about this)
Austin
Old Nov 6, 2002 | 11:33 AM
Asahi's Avatar
Default Re: need help with injector part number (Austin)
good to know. I didn't even look into pre 97.
Thanks - mine are on their way
Old Nov 6, 2002 | 11:55 AM
eviltwin's Avatar
ok well what i am looking for is the ones that are 340's.
i dont know what year or pretty much anything about them.
so i was told i woul dneed the 340's. i have a guy who can get me prelude injectors cheap, but i need to be able to provide him with a part number for them. i called my local honda dealer and they were complete ******** and said ithey dont give out part numbers for the fact that people get their info and buy somewhere else.
Old Nov 6, 2002 | 12:10 PM
Asahi's Avatar
What car are they going in? You didn't sound like you read everything the other guys said. Basically if it is going in a Type-R the 340's do not work without modification.
edit: Happy now steve?
[Modified by Asahi, 3:33 PM 11/6/2002]
sgT's Avatar
sgT
What car are they going in? You didn't sound like you read everything the other guys said. Basically if it is going in a Type-R the 340's do not work.
they can work, you just have to have all the right parts.
Old Nov 6, 2002 | 12:21 PM
Asahi's Avatar
Default Re: need help with injector part number (sgT)
basically what i meant. Won't plug and play like 97+ correct?
Old Nov 6, 2002 | 12:27 PM
eviltwin's Avatar
what would i need ot make them work?
and yes they are for my type r.
Old Nov 6, 2002 | 12:28 PM
Austin's Avatar
That is correct, the pre-'97 injectors require different plugs to be wired in, as well as a resistor box.
Austin
Old Nov 6, 2002 | 12:29 PM
sgT's Avatar
sgT
"do not work" and "arent plug and play" are not the same thing
Austin's Avatar
If you end up going the route of rewiring everything just buy a set of RC injectors with the wiring clips, no resistor box needed.
Austin
Old Nov 6, 2002 | 12:34 PM
Asahi's Avatar
Edited, That better?! Ever start a sentence telling someone to do something and not add the understood "you"?
zylex888
Feb 25, 2006 05:16 AM
HybridCoupe
Jul 8, 2002 08:28 AM
tinkerbell
Jun 17, 2002 12:45 AM
hopelessrex
Jun 16, 2001 03:35 PM
