Best way to fix engine timing - 99 Civic DX
Old Dec 16, 2015 | 06:51 AM
f15Civic's Avatar
Default Best way to fix engine timing - 99 Civic DX
Hey guys I am planning to redo the timing this weekend, and I have been searching and I cant find the answer. I will like to know if the best way to fix the mechanical timing is to just remove the timing belt completely and reset crank gear and the cam?(Can I just rotate both the cam and crank independently to set TDC?) or can I fix it by just loosening the tension enough to slide the belt off the cam and rotate it to the proper TDC markings?
I think I did the timing belt on my wrong, when I installed the timing belt kit this summer. The car idles fine but it drives sluggish with really bad mpgs 150-200 per tank. The car at the time had a bad 02 sensor and a exhaust leak near the exhaust which I later replaced/corrected I could not pin point the issue right way. The car is my second car, and the fact that I havent had time is why it have taken me this long to continue to troubleshoot the issue.
A back in Oct or Sept I checked the timing, by removing the top timing belt cover and setting the engine at TDC and the last time I checked it was was fine, so I replaced wires, cap and rotors with no success. After replacing the rotor and Cap I got a timing light and I was not able to get a good reading as I am not able to see the timing marking on the crank pulley. Which is what is leading me to think that the timing some how is off by a tooth..
Old Dec 16, 2015 | 07:12 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Best way to fix engine timing - 99 Civic DX
you can loosen tensioner to move belt.
if you had a bad o2 sensor. car defaults to rich and drinks gas to preserve itself from lean.
the plastic cover has TDC markings
Old Dec 16, 2015 | 07:19 AM
tony_2018's Avatar
Fish Twig
You should verify the timing first before loosening the tensioner to attemp the adjustment. Take clear precise pictures if you're unsure.
Old Dec 16, 2015 | 07:21 AM
f15Civic's Avatar
Great thanks man, I will do that. I hope I can get this corrected once and for all because this is whats keeping me from using the car a daily lol
Yeah I know which is why I thought the car was behaving the way it currently is, since the fuel trim were off, running rich. But I replaced the sensor and sealed the leaks and the car still drinks gas like there is no tomorrow.
Old Dec 16, 2015 | 07:32 AM
f15Civic's Avatar
I will do that, I will get the engin to TDC first, and then check how off are the cam markings.
Old Dec 21, 2015 | 08:57 AM
f15Civic's Avatar
Thanks for all the suggestions guys, I had a friend help me fix the timing on the car yesterday. It was easier than I though it would be..
I took some pictures of how many tooth it was off. The wired part is that the car had a good idle and everything it just didnt drive right.
I going to start dayling to see how it feels, I might have to adjust the valves, I hope the few times I drove it like that didnt damage the valves.
This first two are how off it was
This pics is after I got it lined up with the TDC marks
This is the ignition timing with the Timing Gun, I got it on the the red mark.
journeyquest
Aug 31, 2014 09:04 AM
D16SohcVtec
Apr 10, 2009 11:35 PM
Next GenRacing
Dec 13, 2005 05:52 PM
95greensol
Mar 1, 2005 09:22 AM
flyrod
Aug 14, 2002 06:38 PM
