should i buy this or not?
Old Dec 15, 2015 | 08:39 AM
89brokendownEF's Avatar
Default should i buy this or not?
it is a accel coil my car is basically a daily driver automatic has clear distrib cap i try to keep it on regular maintenance. i also am wondering should i buy the aem fuel rail will it work with my stock injectors i am just trying to dress up the engine bay.
what are benefits or cons to fuel rail/coil
Old Dec 15, 2015 | 04:37 PM
90Acura's Avatar
Default Re: should i buy this or not?
I like the "lethal voltage". Not good to be shocked, but almost looks as if it's there to impress people. Benn hit numerous times and I'm not dead yet.
For dress up, I can see this stuff, but that's about it. I've heard reports that their wires aren't as good as OEM, so I'd be suspect. I've never seen any real proven data showing that their supposed increase in voltage (if any at all) is giving a notable performance gain over OEM. Same goes for their manufacturing quality and wire insulation class (overall reliability) being any better than OEM, if any.
Old Dec 16, 2015 | 03:04 PM
tamboo's Avatar
10 Year Member
just shell out the extra 25 clams for the best coil:
Amazon.com: Genuine Honda 30510-PT2-006 Ignition Coil Assembly: Automotive Amazon.com: Genuine Honda 30510-PT2-006 Ignition Coil Assembly: Automotive
Old Dec 16, 2015 | 06:56 PM
stocker2shocker91's Avatar
I requested a short story for a title.
that coil MIGHT give you a little stronger spark, an aem fuel rail on a completely stock Honda engine will do nothing.
Old Dec 18, 2015 | 01:59 PM
K20.ek's Avatar
I have that exact coil for the past 3-4 yrs and just gives me stronger spark. But it's a good part and never gave me any problems, as for the wires I would go with ngk as that's what I have now.
Old Dec 18, 2015 | 09:24 PM
wunfstgsr's Avatar
Loved
Community Favorite
Well that coil will be fine but a OEM one is always best for reliability. If you want to have some sort of bling to show under the clear distributor cap its fine why not if thats what you want.
Using a aftermarket fuel rail really doesnt have any much advantages unless you have a heavily modified engine that requires a bit more fuel flow and reduced fuel temp, but besides that it will allow you to use a aftermarket fuel guage as well as a nitrouse feed on the other end of the rail again something for a modified engine. But if you want something to stand out then its fine if thats what you want but no real advantage besides looks.
Old Dec 21, 2015 | 07:55 PM
TOO MUCH TORQUE's Avatar
I would only use genuine parts for ignition parts. They simply are the best and most reliable.
Old Dec 21, 2015 | 10:37 PM
wunfstgsr's Avatar
Loved
Community Favorite
I would imagine he wants the yellow coil to show off under the clear dist. cap.
Old Jan 25, 2016 | 04:28 AM
fastgsr1995's Avatar
I just installed the accel coil and I was really impressed I got it from Oreillys for 50 bucks
Old Feb 4, 2016 | 08:39 AM
trm4life's Avatar
Many honda people will tell you aftermarket is the wrong way to go. I've never had a problem, but as far as reliability you really can't beat OEM. I would personally buy an OEM igintion coil all day long.
I have been running accel wires. There was more throttle response over the "auto parts store" brand wires but your wires are only going to put out what you attach to them. OEM ignition systems are good to many hundred horsepower. If I could get yellow NGK plug wires for my car I'd buy those instead of the accel!
Alcott83
Mar 18, 2013 11:24 AM
arexniba
Dec 21, 2006 04:58 PM
Nataku
Feb 24, 2006 02:59 PM
slowd16z6
Mar 12, 2004 06:34 PM
Mr Hammond
18
May 15, 2003 04:37 PM
