Any universal generically-programmable guages out there?
Looking for something like this: A universal, generic, programmable 2 1/16" digital gauge - not built for any single engine parameter - something I can set the voltage scale(or bounds)/display scale myself.
Initially I would use it to tap into the MAP sensor to read voltage and see true boost. In the future I could tap into any DCv sensor on the engine just by reprogramming the voltage scale.
I know I could use an app that pulls the data from the ECU over bluetooth with my Demon board/Neptune setup - but that is not really what I'm asking about.
I'm tired of the inaccurate analog Autometer-style gauges, and want a dedicated, hardwired solution to show exactly what the MAP sensor is seeing, but that can be repurposed in the future to read other sensors if I choose.
Thanks guys!
Thanks guys!
I knw what you are asking for, but have you considered this?
TunerView Displays | Welcome to HRTuning
Whoa, last time I looked Tunerviews took up the whole dash cluster and looked like what I have attached.
Although these new ones are smaller and cool, I still wish there was an option for the universal round 52mm gauge dimension to fit into the common gauge pods so I didnt have to cut into my OEM dash cluster - or anywhere else for that matter.
I might consider the new small dash kit. Thanks.
Actually you have that completely backwards. The Tunerview (small one) was the first one, then the Tunerview II with large option, and finally the Tunerview RD1 came out more recently (what you posted).
I am not aware of any gauge like you want, but someone might know of one. The Tunerview would definitely show and do what you want plus more...
Frozen E
Jun 8, 2010 03:23 PM
APEXI Si
Apr 29, 2005 11:31 AM
