Boost reading different from all 3 sources
Old Jan 16, 2006 | 01:33 PM
BoostGoneWild's Avatar
Default Boost reading different from all 3 sources
We tunned my car @15LBS and my ? is any of you notice that the reading on the boost gage, boost controller, and map sensor are all 2-3 lbs different. The 15lbs was the reading from the map sensor, the B/C was about 17.5 and the gage was almost 20lbs, is this normal and can it be fixed.
Old Jan 16, 2006 | 01:44 PM
B18 CYA's Avatar
gauge is always off, id go with the map sensor
Old Jan 16, 2006 | 02:07 PM
Default Re: (B18 CYA)
By how much is your gage off? compered to the map sensor
Old Jan 16, 2006 | 02:32 PM
B18 CYA's Avatar
my gauge was saying 20-21 and my map sensor was showing around 17-18
Old Jan 16, 2006 | 03:30 PM
sc4dr's Avatar
Default Re: Boost reading different from all 3 sources (BoostGoneWild)
my gauge reads atleast 1 psi higher than map sensor
Old Jan 16, 2006 | 04:05 PM
EVIL Hx Coupe's Avatar
Default Re: Boost reading different from all 3 sources (sc4dr)
I think it's pretty much the same way for everybody. Remeber when we tuned my car and we finally got it down to a 10psi reading from the MAP ? The gauge was still reading a bit over 12psi.
Old Jan 17, 2006 | 10:13 AM
Targa4Life's Avatar
Default Re: Boost reading different from all 3 sources (EVIL Hx Coupe)
That is the same on mine as well. I consider the map to be most accurate in all cases. Although in regards to this subjuect i wouldl ike to know if when people refer to the limits of honda block and what not are they refering to the Aftermarket guage or the map or what? Im running 8psi on the autometer but the map says like 6.5psi. I make reasonable power like this 235whp but I want MORE! can I go with an additional 23% more boost or can the block handle more? Obviously knife edge tuning can allow much higher boost levels but thats not economical for me.
Old Jan 17, 2006 | 11:16 AM
JDogg's Avatar
Default Re: Boost reading different from all 3 sources (Targa4Life)
what kind of map sensor?? gm sensors are not very accurate over 14psi
What block are you running?. I was at 10lbs off boost with a stock block making around 260whp (GSR Block). That was threw the autometer gauge.
pkopalek
Engine Management and Tuning
Aug 2, 2013 10:07 AM
the.hamburglar
Aug 4, 2007 08:39 AM
Qveon
Apr 30, 2007 10:35 PM
APEXI Si
Apr 29, 2005 11:31 AM
89dxhunchback
Nov 15, 2003 05:10 PM
