d16 96 civic HELP!
Old Dec 10, 2015 | 12:01 PM
Michael Padgett's Avatar
Default d16 96 civic HELP!
So I am new to anything other than jeeps.
I am replacing my headgasket.
I opened up my motor and took off the gasket.
There is a space around the cylinders I have never seen before and its filled with a combanation of oil and a very thin fluid what belongs in that passage.
Coolant? or Oil?? hoping no rain got in there.
Old Dec 10, 2015 | 12:04 PM
92civicdxhatch's Avatar
Default Re: d16 96 civic HELP!
Coolant goes in that space.
The four ports are for oil drain back into the pan.
Your on the right track. Just make sure the T-belt lines back up.
Good luck.
Old Dec 10, 2015 | 12:09 PM
Ohmega's Avatar
That's coolant. Coolant goes around the sleeves to cool the block.
For future reference:
Drain coolant and oil before removing the head.
Have the head machined to prevent you from having to tear the head off again later own the road.
Old Dec 10, 2015 | 12:30 PM
NotARaCist's Avatar
I never narc'd on nobody!
Yep, Honda uses wet sleeves. You're used to closed deck iron blocks that Jeep uses. The space around the sleeves is filled with coolant under normal operating conditions, and the head gasket prevents the coolant from mixing with oil (not it's only job, but you probably know that).
There should be a large bolt on the front of the block, if memory serves correctly. You can remove that bolt to drain everything out of the block. Ideally, you would completely strip the block down and have it hydrosonically cleaned, but I'm guessing you don't want to do all of that. Remove that plug, rinse the sleeves out with some purified water, and you should be alright. Don't let water get into the cylinders, though, and if it does, use a rag to get it out.
Old Dec 10, 2015 | 12:38 PM
Ohmega's Avatar
I believe the coolant drain plug in in the rear of the block, near the oil filter.
Correct me if I'm wrong.
Old Dec 10, 2015 | 12:41 PM
NotARaCist's Avatar
It might be in the rear...
Yep, sorry, I was thinking of a different motor.
Old Dec 10, 2015 | 01:23 PM
omega is correct found it on the back. 19mm.
Thanks guys! I am just cleaning the head and pistons and surface area for the new gasket.
These motors are very different then what I am used to for sure.
Nice to be apart of a forum and community that gives such good and quick feedback and advice.
all the motors with the Y. y7,y8 etc. I guess have the drain on the back. Im draining the oil aswell in case any fluid got into the oil passages.
I used a paint pen to mark the t belt and sprocket/gear and left it at TDC. Should be fine.
Old Dec 10, 2015 | 05:54 PM
any advoce on getting the timing belt back on easily
Old Dec 10, 2015 | 06:28 PM
NotARaCist's Avatar
Use the set pin hole, if there is one in the cam. Loosen the tensioner all the way (or remove it, then bolt it back on).
Old Dec 10, 2015 | 07:02 PM
How many miles on belt and water pump? You may be money ahead to replace those while your that close anyway. Just a suggestion, and we are here to help!
boostedjdmdc2
Jun 2, 2009 08:49 PM
lakerschamp2000
Apr 20, 2009 10:51 AM
oranginal
Mar 30, 2009 07:39 AM
Sam268
Mar 2, 2004 10:20 PM
