Del sol trunk floor/lining dimensions
Old Dec 9, 2015 | 01:14 AM
Kanibaals's Avatar
Default Del sol trunk floor/lining dimensions
Made a template for trunk floor board and lining.(attached)
For printing scale is 1:1@100dpi
Old Dec 9, 2015 | 05:14 AM
Ohmega's Avatar
Default Re: Del sol trunk floor/lining dimensions
What are the 3 rectangles for?
And what unit of measurement?
Nice! Definitely worth keeping this.
Old Dec 9, 2015 | 05:38 AM
HairyHarry's Avatar
Probably the foam pieces that stick under the board.
I need to make one, the oem one is really warped from water leakage. I was thinking maybe cutting one out of plastic or something that doesn't absorb water
Old Dec 9, 2015 | 05:42 AM
Ohmega's Avatar
You're exactly right, you saying that sparked my memory.
Why not fix the leak instead?
Old Dec 9, 2015 | 11:52 PM
Kanibaals's Avatar
Measurements are in millimeters(mm) obviously, could change it to inches if needed
Yes these 3 rectangles are places where to glue foam spacers and the round ones are holes for OEM plastic clips. I could add some notes to it.
I made mine some years ago from moisture resistant plywood and it holds good. Even fixing leaks there are lot of condensation moisture as the large trunk lid catches moisture and water drips. The cabin ventilation for DelSol is poor.
Nave43
Sep 30, 2014 03:58 PM
typac69
Dec 6, 2008 09:25 AM
hermanssol
Jan 26, 2008 05:42 PM
hermanssol
Jan 14, 2008 09:49 PM
