zc piston question.
Old Nov 6, 2002 | 07:50 AM
APEXI Si's Avatar
Default zc piston question.
ok here is the deal. I pulled the head off my friends motor to replace the gasket and the pistons were black as hell and even had ash on them. What to do about that. Is the motor even good?
Old Nov 6, 2002 | 08:03 AM
my_slow_civic's Avatar
Default Re: zc piston question. (crx616)
Excess carbon = running rich
Old Nov 6, 2002 | 08:06 AM
APEXI Si's Avatar
Default Re: zc piston question. (sirk)
so what do I do. Can I just go in there and take rag to it and clean it up or is th motor still ok. I am thinking about buying it from him and then adding some boost. what is you guys opinion. thanks
Old Nov 6, 2002 | 08:27 AM
keithv's Avatar
you can clean the piston tops, but that still means the motor is running rich for some reason. is it a stock motor?
Old Nov 6, 2002 | 08:37 AM
You could possibly correct the problem with a fuel pressure regulator, and FP gauge. But that still does not explain why it is running rich.
Old Nov 6, 2002 | 10:02 AM
APEXI Si's Avatar
yea stock motor... I wil give it a try
Old Nov 6, 2002 | 11:35 AM
Mugen Dom's Avatar
u can leave the carbon build up which is comon for old motors and it will slightly up ur compression a lil bit nothin to worry about
Old Nov 6, 2002 | 03:59 PM
ZC_powered_4dr.'s Avatar
motors not bad, if its running rich check the timing u might have to up it a couple of degrees.
Old Nov 6, 2002 | 06:04 PM
Sonic's Avatar
Default Re: zc piston question. (ZC_powered_4dr.)
This buildup on the pistons is normal after a good number of miles. Use some degreaser to clean it up and its fine.
Old Nov 6, 2002 | 07:16 PM
1SlowB16EF's Avatar
put it back together and go to a dealership and buy some engine top cleaner... you put it in through a engine vac source and it will clean the **** out of it... but you DO need to clean it... carbon gets hot and creats hot spots that WILL cause detonation
Old Nov 6, 2002 | 08:16 PM
CRX-RX's Avatar
Default Re: zc piston question. (1SlowB16EF)
JMO ZC + Boost = The build up is fairly common, just clean it off and slap it back together.
Old Nov 7, 2002 | 06:13 AM
Mugen Dom's Avatar
Default Re: zc piston question. (CRX-RX)
teh carbon also fills in gaps in the piston rings from old age and such which holds compression cleaning it with seafoam or whatever may cause a drop in compression
Old Nov 7, 2002 | 06:34 AM
APEXI Si's Avatar
Default Re: zc piston question. (JdMB16Ahatch)
If I am going to boost it the n would I want lower compression or should I just leave the way it is. I also have fpr already ordered.
Old Nov 9, 2002 | 02:10 PM
CRX-RX's Avatar
The rods in the ZC aren't capable of holding together much over 200 hp, and the rod bearings seem to go very easily on boosted motors. If you want to boost on a ZC and have it remain reliable, I would consider rebuilding the bottom end with stronger parts.
frankenstienEk
Oct 8, 2006 10:02 AM
dangerranger21
Jul 9, 2006 09:55 PM
r7
Sep 18, 2003 11:47 PM
BseriesHatch
Mar 25, 2003 08:34 AM
