Suspension & Brakes Theory, alignment, spring rates....
40 mph and below shake
Old Dec 2, 2015 | 04:38 AM
Treyschls's Avatar
Default 40 mph and below shake
I have a bad shake when braking around 40 mph and below only
Old Dec 2, 2015 | 06:33 AM
TheRealMrHonda's Avatar
Default Re: 40 mph and below shake
Have the front rotors machined with an on-the-car brake lathe. That will most likely take care of it. If not, at least you have eliminated the most likely cause.
Old Dec 3, 2015 | 05:22 PM
Tachi's Avatar
Warped rotors would be most apparent when applying the brake. Examine your suspension for any play in the ball joints or tie rods. Check your cv's too as worn units can cause that.
Old Dec 6, 2015 | 01:36 AM
slowcivic2k's Avatar
Come on, at least provide us with a vehicle and history of the problem. There are millions of potential causes for this type of problem. Follow the posting rules, and provide proper information!
Old Dec 7, 2015 | 06:16 PM
Treyschls's Avatar
A millions causes? I have new upper and lower ball joint and new inner and outer tierods. A new tire on my passenger front and an worn driver side front tire. Could a worn rack and pinion cause this? Ive been having the car since 07 and as far as I kno its never been changed before I had it..
I put EBC rotors on in 2013.
And also had to change one of my rear calipers cause it wasnt plunging recently this year
Old Dec 9, 2015 | 12:14 AM
Is this on a Ford F-150?
You want help or not? Provide us with real information.
Old Dec 9, 2015 | 04:55 PM
Treyschls's Avatar
Lets be realistic. We're on a Honda page so noone on here should have anything to ask about a Ford. 1996 Honda Accord Ex coupe 2.2L Vtec.
Didnt kno Hondas could be so different from one another besides stuff like rotors that have to be pressed on(Accords have to be pressed between hub and the knuckle)and ones that dont..... The exact day I put the rotors on was Feb 8, 2013
Old Dec 10, 2015 | 11:28 PM
Let's be realistic, no one knows what you drive, because you have failed to mention it. Its pretty hard to give good VEHICLE SPECIFIC advice, when you fail to identify your vehicle.
There are several vehicles that used a trapped rotor design, where the wheel hub has to be pressed out to remove the rotor from the vehicle.
Now, again with the lack of good diagnostic information on your end, when did this problem start? What was the last thing done to the car prior to this problem occurring. Since you have failed to provide basic problem history, start with that first.
Old Dec 12, 2015 | 08:04 PM
Treyschls's Avatar
I would have went to model-specific if I knew I couldnt get basic answers here nonetheless You know what.. Conversation over.
**** face! First take a big step back and LITERALLY **** YOUR OWN FACE!
Now I dont know what kind
Of Pan-Pacific bullshit power play your trying to pull here
Whatever your thinking you better think again
Otherwise Im gonna head down there and I will rain down an unGodly firestorm upon you.
You're gonna have to call the ******* United Nations and get a
******* binding resolution to keep me from destroying you!
Im talking scorched earth
I will massacre you!
I WILL **** YOU UP!!
TT
street_ride14
Jun 22, 2012 01:56 AM
CBL9
Nov 11, 2010 10:28 AM
SingleCamin
13
Jan 5, 2010 10:55 PM
Gsir8
Feb 3, 2007 09:30 PM
SlammedHatch90
Jan 30, 2003 08:46 AM
