Fuel Pump not getting enough power 4-6v
Old Dec 2, 2015 | 12:15 AM
NovaRex's Avatar
Default Fuel Pump not getting enough power 4-6v
hello everyone i posted on here earlier about a bad fuel pump long story short my car was running and i accidently pressed my killswitch on the fuel pump, i turned on/off many times and still no start i didnt even hear the fuel pump prime, overall everything was rusted and damaged so i installed all new parts. once installed i put the key in the on position to let it prime and still....i didnt hear anything and still no start. brought out my DMM and from the connector that connects to the fuel pump/sending unit only reads 4-6 volts(bounces in between). i dont know what to do anymore, any advice or have you had similar situations?what did you do? thanks in advance.
Things i replaced: new fuel straps/tank/sending unit/hoses/fuel hanger/pump/strainer/bolts/Main Relay.
Help me get my rex back on the road D:
Old Dec 2, 2015 | 10:51 AM
kp's Avatar
kp
Default Re: Fuel Pump not getting enough power 4-6v
Is the killswitch still installed? Have you tested the pump without the switch wired in?
Old Dec 3, 2015 | 10:11 AM
NovaRex's Avatar
I have removed the kill switch, i tested the pump it works fine. it isnt getting enough power though from the battery tho ;/
Old Dec 4, 2015 | 04:17 PM
acmoc's Avatar
This happened to me at school once.
Was my distributor
Could be your main relay
Do you hear it clicking?
Old Dec 4, 2015 | 05:10 PM
v4lu3s's Avatar
RTFM
test your fuel pump out put from the main relay.
carracr625
Apr 19, 2019 06:29 AM
Chris del sol
Apr 16, 2013 10:42 PM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
ill phil
Apr 23, 2003 11:58 PM
