Idleing problem Honda Crx 1988 dx
I bought my honda about four months ago nd love it one of the only main problems is the Car will idle up the way to 2000 rpms some times nd it rarley idles at the regular 750 rpms thank god its a stick shift cuz it only does it on idle tha guy that sold it to me said it might be the throttle position switch, i dont really know how to make sure
I'm sorry my question was how do i see if it is for sure my throttle position switch my Blinking Led Light says Code 7 Which should be it which i just figured out(Which Honda told me it would cost 80 bucks to test my Blinking light)So Am i right? or could it still be my air flow censor or something else
Since you have an idle problem and a TPS code, I would check the TPS sensor. It's not hard but the best way to check it would be with a digital storage oscilloscope which most people don't have. Instead of the dealer I would recommend finding a good independent repair shop, preferably one that specializes in Hondas.
In my 90 si the tps is just a variable resistor. If this is the setup on your 88 you can test it with a $10 multimeter and the info here; https://honda-tech.com/tech-misc-15/diy-calibrating-voltage-tps-2947986/ or here; https://honda-tech.com/honda-crx-ef-civic-1988-1991-3/official-honda-tps-wiring-calibration-thread-2830131/
In my 90 si the tps is just a variable resistor. If this is the setup on your 88 you can test it with a $10 multimeter and the info here; https://honda-tech.com/tech-misc-15/...e-tps-2947986/ or here; https://honda-tech.com/honda-crx-ef-...hread-2830131/
Type 56
Nov 3, 2022 08:56 AM
