EG or EK springs under EG2 del Sol
Old Nov 28, 2015 | 11:09 AM
Matyikaaa90's Avatar
Default EG or EK springs under EG2 del Sol
Hi,
I have a del Sol VTi (US VTEC) which I bought with Koni Sport shocks and Eibach Pro-Kit springs. I don't know how old my springs are but I assume they must be old/worn because my car sits so low that I can't even normally put my fingers between the front fender and the tire.
On good roads it handles amazing and the car is very stable, however, when I drive in the city I can barely go over speedbumps without scratching the resonator or destroying my mudflaps. Also when I'm driving down/out of the parking garage it even rubs my tires.
I was gonna buy coilovers and be done with this height issue but I realized it might be just a waste of money as I would not adjust them all the time and my Koni Sport shocks are very good.
So I have to replace my springs and it might sound silly but I would buy Eibach Pro-Kit springs again. I know they are good springs for spirited/daily driving. BUT Eibach made these springs for the Civics, either EG or EK, and not for del Sols. If I had the S model(then I would be sad because it's slow :D) then I would just buy the EG springs because the S is about the same weight as the 5gen Civic. However, the VTi (VTEC) is the heaviest of them all, it is 200 pounds heavier than the S model.!
Which springs should I go for? As far as I know EG and EK springs are the same size and either would fit my car. What do you suggest? Does anyone have a picture of an EG2 on Pro-Kit springs?
Old Nov 28, 2015 | 12:08 PM
v4lu3s's Avatar
RTFM
Default Re: EG or EK springs under EG2 del Sol
What perch height is the spring seat on? You may be able to raise it up slightly and save money...
Old Nov 28, 2015 | 12:21 PM
they are on the highest perches both front and back. I don't mind buying a new set as long as it's good, I just would like to avoid buying twice.
urbach
Feb 1, 2011 05:31 PM
silva95teg
Aug 16, 2005 08:32 AM
idriveadelsol7
Suspension & Brakes
Jul 31, 2005 12:45 PM
90civichb
15
Apr 1, 2004 08:55 PM
j-bird
Dec 22, 2003 10:32 PM
