Misfire all cylinders
Old Nov 26, 2015 | 07:11 AM
Recluse's Avatar
Default Misfire all cylinders
I have a 1999 civic ex which just started to shake everytime I would accelerate yesterday and today the check engine light turned on and it even started to blink at one point but it stopped blinking. Now before this I had take the car to get tested for emissions test and it failed due to the catalytic converter so I looked online and i found out that scotty kilmer had luck putting one gallon of lacquer thinner in the fuel tank. So i tried that and about two days of driving this started to happen. Is there any suggestions of what could have gone wrong?
Old Nov 26, 2015 | 07:20 AM
Recluse's Avatar
Default Re: Misfire all cylinders
Could it be something as simple as a fuel filter?
Old Nov 26, 2015 | 08:18 AM
that_boy_sammy's Avatar
Why would you do that?? I would drain the tank,put fresh gas, prime the old fuel/lacquer lol out of the fuel filter(with it disconnected into a bucket) for 10 minutes. Then put on a new fuel filter,change the spark plugs, run seafoam through it. After I would get a new cat welded on which should've been done the first time to avoid all this.
Old Nov 26, 2015 | 08:19 AM
Former User's Avatar
Pull all CEL codes and post them.
Old Nov 26, 2015 | 08:20 AM
Recluse's Avatar
You're 100% right i screwed up ima do that asap i wont drive my car till then thank you!!
Old Nov 26, 2015 | 08:24 AM
Recluse's Avatar
Codes are P0301- Powertrain
P0302- Powertrain
P0303- Powertain
P0304- Powertrain
P0300- Powertrain
Random/Multiple Cylinder misfire detected.
P1399- Powertrain
Old Nov 26, 2015 | 08:28 AM
How old are the spark plugs, spark plug wires, cap, and rotor?
Have you removed the distributor cap and inspected the internals?
Old Nov 26, 2015 | 08:30 AM
Recluse's Avatar
The distributor is new, im not sure how old the spark plug or spark plug wires are but they look good still im not very good with cars sorry
Old Nov 26, 2015 | 08:32 AM
Start by replacing both^ and then go from there.
Old Nov 26, 2015 | 08:33 AM
Recluse's Avatar
Will do, any recommended brand? thank you
Old Nov 26, 2015 | 08:38 AM
Honda spark plug wires and the NGK plugs recommended in the Owner's manual for the D16Y8 engine.
Old Nov 26, 2015 | 08:39 AM
Recluse's Avatar
Thank you ron
Old Nov 26, 2015 | 08:40 AM
89b20crx
Mar 8, 2011 09:54 AM
1sikhatch
Honda Civic (2001 - 2005)
24
Mar 21, 2010 02:49 PM
supermario680
Sep 26, 2008 04:14 PM
dobbs1027
Dec 28, 2004 03:17 PM
blackhatchy
Dec 4, 2003 05:20 PM
