Mixing clutch components, exedy w/ fuji
Old Nov 25, 2015 | 08:37 AM
TOO MUCH TORQUE's Avatar
Default Mixing clutch components, exedy w/ fuji
Hello
Car is a 2001 acura integra LS
I bought the exedy khc05 and from reviews, it says the pressure plate is incredibly soft. Something i do not want. Would there be an issue mixing the exedy friction disc with an OEM pressure plate made by FCC Fuji?
I am a fan of the oem clutch pedal feel and would like to retain that.
Old Nov 25, 2015 | 08:53 AM
B_Swapped93's Avatar
Default Re: Mixing clutch components, exedy w/ fuji
Sure with reputable brands no issue, heck kids on ebay do it all the time claim it's an "exedy kit" yet give you a pos friction disc it's always stated somewhere in small writing.
I looked up that clutch I says it's a oem replacement, I see no reason it would be softer than the oem one it's already soft. There's no harm in it just seems od
Old Nov 25, 2015 | 09:00 AM
All consensus says that it is much lighter than OEM. I've actually driven an rsx-s with exedy replacement and do remember it being incredibly soft.
Old Nov 25, 2015 | 03:03 PM
cheapskate's Avatar
FWIW I have the Exedy OEM replacement clutch in my GSR and its been great. I have 35,000 miles of **** pounding on it, launches, ripping shifts, 10 track days, and it is still performing great.
Yeah, the pedal feel is not "heavy" but who really cares. I bought it on amazon for $110.
Old Nov 26, 2015 | 07:06 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Brand new clutches are typically softer. They increase in pedal effort after a while. While the Exedy replacement is probably a little bit softer than stock, when *either* is brand new, they feel like pushing on air.
Are you buying a brand new pressure plate from Honda? I would buy the whole clutch set from Honda if you're going that route. The bearing and disk are of higher quality than the exedy replacement...and you will have already covered the bulk of expense with the pressure plate. Snag some Honda high temp urea grease while you're at it. Nothing works quite as well as that stuff.
Alternatively, you could buy a Exedy stage 1 for a more agressive feel.
Old Nov 26, 2015 | 09:41 AM
That is good news that it gets harder over time. I may just stick with the exedy replacement and get use to that feel. Going to pick up the package tomorrow and see what brand the throwout and pilot bearing is. If not koyo or nachi, i am going to buy oem throwout and pilot bearing off of ebay.
But do you think the fuji pressure plate will work well with the exedy friction disc?
Old Nov 27, 2015 | 05:48 AM
B serious's Avatar
The FCC plate should work fine with an exedy disk. Quite a few S2000 people who were trying to find a cheaper clutch solution that wouldn't fly to pieces would buy a FCC Honda disk and mate it to an Exedy PP. You're doing it backwards...but it *should* still work.
Old Nov 27, 2015 | 01:24 PM
EnjoyTheRideDC2's Avatar
The Exedy replacements lately have come packaged with a china made throw out bearing. Pilot bearing I cant recall the manufacturer. If you plan on mixing clutch components, be sure they are new pieces. The friction material on the disc relies on a clean pressure plate surface to grab onto.
Old Nov 30, 2015 | 09:54 AM
vladd's Avatar
When I was replacing the OEM clutch in my 00 Integra with an Exedy OEM replacement 4 years ago, the throwout bearing had the same marking as the original one and looked exactly the same.
Old Nov 30, 2015 | 07:54 PM
B serious's Avatar
I don't believe Exedy kits come with Nachi bearings. I think they now come with Nacho bearings. They're not your bearings.
Sorry.
For real though. They don't consistently come with Nachi bearings. And even if they do, they are likely not the same quality as the ones spec'd by Honda.
The Exedy B/D/H series kits are still not bad overall. Some K series applications work well. Its a firm "no" for F20C engines.
cletus11
Dec 10, 2011 04:34 AM
Adam.
Jan 27, 2004 05:24 PM
-[95cxhatch]-
Aug 4, 2003 11:06 PM
TypeSH
Mar 21, 2002 02:23 PM
