Swap
Old Nov 24, 2015 | 04:23 PM
Roman Rome's Avatar
Default Swap
what do i need to switch from a d16y8 to b20b in a 1999 Honda Civic coupe.
A break down of parts.
Old Nov 24, 2015 | 04:32 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Swap
The first thing you need is the willingness to put forth a modicum of effort, which you obviously haven't.
https://honda-tech.com/honda-civic-d...tions-1998336/
Old Nov 24, 2015 | 07:48 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: Swap
Engine Alignment
Blinker Fluid
Engine Rotator Splint
Cross drilled brake lines
Piston return springs
Muffler bearings
Crank gear liner
that should get you started.
Old Nov 24, 2015 | 08:30 PM
NotARaCist's Avatar
Default Re: Swap
Old Nov 24, 2015 | 08:43 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: Swap
The engine must have a minimum of 40% oil, 58% metal, and 2% water. Gets the best performance.
Old Nov 25, 2015 | 05:17 AM
ForMyWoman's Avatar
Default Re: Swap
Check the link in my signature. The first post will be a good reference point for you. I am planning a b20 swap in my 2000 Honda Civic and all the research I been doing will be found there.
Also, you'll yield more fruitful answers if you typed this kind of question in a Google search bar than a post on H-T. This place is full of first posts like yours and all of them get the same response.
Old Nov 27, 2015 | 12:54 AM
Roman Rome's Avatar
Default Re: Swap
What link are u talking about
Old Nov 27, 2015 | 12:56 AM
Roman Rome's Avatar
Default Re: Swap
What link?
Old Nov 27, 2015 | 05:12 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Swap
https://honda-tech.com/honda-civic-d...-swap-3262303/
candeekidone
Jul 30, 2021 07:41 PM
Xoon
Apr 10, 2020 07:32 PM
skylynx06
Honda Civic (2001 - 2005)
Jul 31, 2013 09:42 PM
dstockbridge
Jan 30, 2012 04:30 AM
