E85: Hondata S300v3 or AEM EMS v2
I'm sure this has been answered, but I never really got a complete answer reading through the previous postings about the Hondata S300v3 vs the AEM EMS v2 on e85 and real time adjustments to fuel grade. I currently have a Zeitronix Ethanol Content Analyzer unit already.
Being in the Midwest we don't get a consistent E85 blend. It will be E70 in the winter and fall and then E85 in the summer. Which unit would compensate better? From reading it looks like the AEM can translate it better than the S300, but would the S300 be more than capable of doing the same thing? This would be a on a daily driven vehicle. Thanks!
Absolutely the AEM v2... it has actual map blending capabilities. What I mean by that is you could make a map for E70 and then a map for E85 and the AEM can seamlessly blend the two maps together for any ethanol content anywhere in-between.
With the S300 v3 is just a global modifier. Some trickery can be done, but it definitely isn't as seemless as the AEM.
You didn't need the Zeitronix ECA unit for either system though, only a GM FF sensor. For what it's worth, I have the Zeitronix ECA unit myself and am currently running the S300 v3, but I have been on E85 since v1.
As a longtime S300 user even I say go AEM all the way. If I wasn't so far into the S300 setup I would use AEM. The S300 is a great system for what it is but I really don't think you can compare the 2. One is basically a hack (it's a great hack but it still is limited by the ECU) while the AEM is a true stand alone.
Ive went back and forth on e85 and 91 plenty of times and the tune always stays on point.
Download the software on aems site and check out all the flex fuel settings
Then go do the same with s300
I'm a noob at tuning, and most tuners aren't giving you a specific answer or good answer unless you've committed to them. lol
Youre going to need the software either way no matter what plat form you choose
Download them both and browse around.
What are you going to do when you want to make a small change to your idle? Go back to the tuner?
Download them and make a choice then familiarize yourself with the platform you choose
I've been following your build since it's very similar to mines. Are you planning to go e85 at all or is 93 your sticking point? My thought is that 93 = less maintenance, E85 = more tuning room but more maintenance. I am from MN, so the car will be sitting for the whole winter.
I am interested to see what your build does. I love the TR3030R.
Oh and it's "You are a retard." Not "You are retard." Unless you were trying to say, "You are retarted?"
It's a boosted setup.
81.5mm CSS B18C1 Block
10:5.1 Arias Pistons
Eagle Rods
LS Crank
ARP Headbolts
GSR Head Stock Ports
GSC T1 Cams
GSC Valvetrain (Springs, Retainers)
ID2000
Skunk2 Pro Series Manifold
Skunk2 Alpha 64mm TB
STC TR3030R
Sypnase Ram Horn Manifold
Quick rundown of the setup.
Eagle Rods
LS Crank
ARP Headbolts
GSC T1 Cams
ID2000
STC TR3030R
Eagle Rods
LS Crank
ARP Headbolts
GSC T1 Cams
ID2000
STC TR3030R
Eagle Rods
LS Crank
ARP Headbolts
GSC T1 Cams
ID2000
STC TR3030R
Thats pretty smart
Thanks everyone all though I went against the grain on this one. I feel that hondata will be sufficient for my needs at this time. Thanks again!
Have a good one folks!
Don't think I'm skimping. I feel the hondata although not the best will be sufficient for my needs. If I was skimping we'd be talking about crome or uberdata! Lol
Getting a good ems would actually be going against the grain.
Good luck
I apologize i just hate seeing it time and time again
1500 dollar turbo
Injectors
Cams
Etc
Then The most crucial part everyone chooses hondata
Why because it takes less time to tune than an actual stand alone
Think if that benefits your end goal
1500 dollar turbo
Injectors
Cams
Etc
