How do you install the Greddy Black Box??
Old Nov 6, 2002 | 02:19 AM
Maverick77's Avatar
Default How do you install the Greddy Black Box??
I believe I'm ready and apt enough to install my Greddy turbo kit on my sohc Civic. Many of you suggested that I should just do it myself since its a simple bolt on kit. I've completely read over turbocivic.net and the install was for the newer Greddy kits that come with a blue box. I've also done a search with no luck... I just want to make sure I can do the wiring my self as well... Thanks!
Old Nov 6, 2002 | 06:26 AM
DeepSi's Avatar
Default Re: How do you install the Greddy Black Box?? (Maverick77)
This is the best i could find
Here you go:
http://tonrog.homestead.com/files/blackboxwiring.jpg
hope this helps.
-deepsi
Old Nov 6, 2002 | 08:50 AM
Maverick77's Avatar
Default Re: How do you install the Greddy Black Box?? (DeepSi)
I appreciate it man
But where exactly do you connect the blue, black, red, green, and white wires? Sorry if its a dumb question.
Old Nov 10, 2002 | 11:30 AM
Maverick77's Avatar
anyone?? please help!
Old Nov 10, 2002 | 11:55 AM
DeepSi's Avatar
i found this...
https://honda-tech.com/zerothread?id=266571
you can IM, turbo sol if you have questions
there is one wire that runs into the ecu. the others are on the iat (intake air temperature sensor), map sensor, and the coolant sensor.
taken from https://honda-tech.com/zerothread?id=216944
it looks like one wire is spliced into the ecu, and the other four wires go into the engine compartment, and splice into the IAT and the coolant sensor. just use some shrink tubing, and solder and it should work out. http://tonrog.homestead.com/files/blackboxwiring.jpg
hope this helps you out.
-deepsi
Ls InTeGrA RaCeR
Nov 9, 2004 05:02 PM
r1lorenzini
Feb 13, 2004 01:45 PM
ek_will
Aug 1, 2003 08:58 AM
xlr8
Jun 21, 2003 07:02 AM
xXx Justin xXx
Nov 27, 2002 04:47 AM
