OBD1 to OBD2
Old Nov 23, 2015 | 09:39 AM
jzavala's Avatar
Icon5 OBD1 to OBD2
Hey Guys,
I've been searching for weeks now and still no luck.
I have a 93 Civic DX with a blown z6 motor. I bought a 99 y8 with ecu, Tranny and engine harness. I tried to chase all the wires from the old to the new and still nothing. I want to get this thing running since its my daily driver.
could anyone direct me to any info that can shed some light?
There is the driver side plug that i cant make out what wires go to what. Im just about to call an electrician but if i can save some money i wouldnt mind doing the work myself and keeping it as clean as possible.
Thanks
Old Nov 23, 2015 | 11:20 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: OBD1 to OBD2
You're overthinking it. Converting your entire car to OBD2 is silly. Keep your stock harness. Get your ECU socketted (Zenocron can do this for you), and install a Y8 "chip" (Zenocron can also do this for you). Install the Y8 using the original OBD1 engine harness, install the chipped ECU, and boom, you're done.
Old Nov 23, 2015 | 12:24 PM
jzavala's Avatar
I want a clean Installation, that's why im looking for help with getting the the right connections to the fuel pump, starter and dash components. im not running anything complicated just need help with the wiring. I dont want to chip anything when i already have a factory ecu.
There is a plug at the end of the engine harness that goes to the interior harness, I need help with finding what wire goes to what wire.
Old Nov 23, 2015 | 01:13 PM
NotARaCist's Avatar
These are things that have been done by thousands of people before you. We know how to do it. We know what we're talking about. If you want a clean install, then follow our lead.
.:FFS TechNet : Scenerio 2 : OBD2 Engine into an OBD1 vehicle :.
The important part that you need to read from that page is this, right here:
If you were wondering about using a U.S. OBD2 civic engine wire harness - fuggedaboudit - you cannot use an OBD2 civic wire harness in an OBD1 vehicle because of it's 1-piece design (harness is one piece from the engine through the firewall, all the way to the ecu plugs). OBD1 civic/delsol/integra & OBD2 integra's all use a 2-piece design (harness breaks off at the shock towers) which makes it possible for backwards compatibility.
Have I made my point yet?
Old Nov 23, 2015 | 01:31 PM
jzavala's Avatar
Yes, you have.
I know that you guys know what you're talking about, that's why I'm here looking for help. I was just under the assumption that if i could link all the proper wires to the proper wires, it would work just fine.
The reference page you provided is really helpful, i have to really look through it and see what i can gather from it.
As far and what i assumed, with the matching of the proper wire to the proper wire, am i just chasing my tail or will it work?
Old Nov 23, 2015 | 01:42 PM
NotARaCist's Avatar
You're chasing your tail.
Old Nov 23, 2015 | 01:49 PM
jzavala's Avatar
heard you loud and clear.
Old Nov 23, 2015 | 04:33 PM
tony_2018's Avatar
Fish Twig
No...you haven't
Old Nov 23, 2015 | 06:04 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Also so yer not chasing ghosts it's Xenocron.com with an X not a Z.
I am not sure if even google would fix Zenocron....
Old Nov 23, 2015 | 06:13 PM
jzavala's Avatar
Originally Posted by tony_2018
No...you haven't
right...
Thanks man. already found it and looking into it
Old Nov 23, 2015 | 06:59 PM
NotARaCist's Avatar
Ah, yes, with an X. But I just tested it, and yes, Google knows what you mean when you type it with a Z too Good catch TomCat.
Old Nov 24, 2015 | 01:18 PM
HondaPartsHero's Avatar
Technical Hero
Look forward to adding an extra oxygen sensor right past your catalytic converter, adding fuel tank pressure sensors including the fuel tank from a 96-00 vehicle, wiring in all the EVAP sensors including using a charcoal canister from the vehicle the ECU is from. I'm not really sure if you're trying to use the Y8 harness or a combo of both?
Old Nov 24, 2015 | 02:07 PM
NotARaCist's Avatar
I think I've talked him off that ledge, HPH, but yeah, all more reasons to NOT try to gerry rig an OBD2 harness and ECU in there.
Old Nov 24, 2015 | 03:20 PM
jzavala's Avatar
I wont be attempting this any longer just need to find out what i need now to get this thing back on the road.
I have my old z6 harness, a p28 and a y8 motor, harness and ecu. Can you shed some light on what i can do to get this thing running?
Old Nov 24, 2015 | 04:04 PM
NotARaCist's Avatar
Use the Z6 harness. Install the Y8. Call Xenocron, and get them to socket your P28. Also have them make a Y8 chip for you. Easy as that. You may have to do some minor wiring work, but there's a sticky thread for that.
https://honda-tech.com/honda-civic-d...guide-3146770/
Old Nov 24, 2015 | 04:22 PM
jzavala's Avatar
Thanks, im going through the sticky right now. Since i Live in Cali, i need someone closer than Xenocron. Is there anyone on the west coast I can drive to?
Old Nov 24, 2015 | 04:43 PM
NotARaCist's Avatar
Oh, you live in California? You're boned then. Sell the Y8, find a Z6, and do a direct replacement. CA's emissions laws will royally screw you over.
Old Nov 24, 2015 | 04:56 PM
jzavala's Avatar
Yeah, i know. I bought this thing because it was a good price and need something to get me to work.
I just want to get it going and then worry about the rest later.
I already have the engine in the car and since i thought i could use the engine harness, i cut a hole in my fire wall. I made a pretty clean hole so now i have to close it up. It's all ready to go with the exception of the wiring.
Since now i know i cannot use the obd2, what are my options?
Can i use my existing p28 and rewire the distributor? I'm asking since i need something soon. Xenocron might take some time to get me what i need or am i casing my tail with that too?
I really appreciate the help.
Dvsmoov
Mar 10, 2016 09:32 AM
JesseBizz
Jul 28, 2009 02:46 PM
D16SiHatch
Jan 26, 2008 05:46 PM
Cheetos408
Sep 5, 2007 09:39 PM
Aquafina
Jun 8, 2007 02:18 PM
