civic 95 rpm fluctuate / air-cond not functioning (solved)
Old Nov 23, 2015 | 05:16 AM
Mil Mercs's Avatar
Default civic 95 rpm fluctuate / air-cond not functioning (solved)
my civic 95 sohc rpm fluctuate when i switch on the air-condition. the air -condition also blowing the plain air. the problem usually solved when i disconnect the MAP sensor and then hook it back again. but yesterday, i drove the car in a long journey and then this thing suddenly happened. this problem seems cannot be solved after i have done the seems method. i have no idea why it has something to do with air-conditioning system. i search through the forum and cannot find the exact answer. please help me. the weather here is too hot and i cannot drive without air-cond system. my sweat is dripping and it is very uncomfortable.
Old Nov 23, 2015 | 07:39 AM
delsolintegra's Avatar
Default re: civic 95 rpm fluctuate / air-cond not functioning (solved)
The A/C is a heavy load on the engine that effects Manifold pressure. If you are not having any other engine symptoms it may just be that the rubber O-ring of the MAP sensor may not be sealing anymore. Probably the original now 20 year old rubber O ring.
The O ring is part #16075-P07-000 about $3 or you can get a similar O ring at a hardware store.
Put some silicon grease on it just to help seal.
Old Nov 23, 2015 | 08:01 AM
Mil Mercs's Avatar
thank you for your info. i will find out the o ring at local store tomorrow. before i read your reply, i'm doing some cleaning work to the IAC . took out the IAC there are 2 hose connected to the valve. mine is look similar in this picture below. what I see there are water dripping when i loosen the clip. Is that hose for cooling liquid ?
Old Nov 23, 2015 | 08:13 AM
oneheadlight's Avatar
yup it's coolant..
Old Nov 23, 2015 | 08:19 AM
Mil Mercs's Avatar
so the o ring for the MAP sensor locate inside the sensor and nothing to do with IAC valve? lets give it a try tomorrow as I still didn't sure what causing this and I will update it here. anyway thank you for the part #
Old Nov 24, 2015 | 08:40 AM
Mil Mercs's Avatar
i had replaced the o ring but it looks like the idle problem can't go away. even the o ring on the MAP sensor still look good.
Old Dec 8, 2015 | 01:48 PM
Mil Mercs's Avatar
UPDATE: Solved!!! actually the air-condition compressor belt already broken mid-driving and the leftover dropped somewhere on the road. sent to workshop for diagnosis, the mechanic told me the belt for compressor are missing. it's funny how i didn't notice that thing was already not there. i replaced all 3 belts, for alternator, compressor and power steering. now my rpm back to normal.
jdm95
Engine Management and Tuning
Feb 2, 2010 08:10 PM
notsostockcivic
Apr 30, 2008 08:05 AM
Slow Eg8
May 28, 2007 06:19 PM
EGP
Jul 8, 2005 12:04 PM
ce
Jun 24, 2002 09:31 AM
