Transmission & Drivetrain Gearboxes, Differentials, Clutches
02 crv new clutch stalls in neutral wont drive
Old Nov 22, 2015 | 04:58 PM
stc876's Avatar
Default 02 crv new clutch stalls in neutral wont drive
i got a 2002 crv I just did a motor swap in I put a brand new clutch on a used flywheel......... When I started it up the clutch wouldn't disengage and lunged forward in first.......I tried jamming it from neutral to first with the clutch in and it made a horrible sound.... I diagnosed a bad master cylnder and replaced it....... Now the clutch does disengage but when I engage the clutch it stalls even in neutral in first the car will not move forward.... I can use the gas to keep the car from stalling but it only burns the clutch and doesn't not move forward any help would be great........... I have been searching for hours....wondering if it's stuck inbetween gears or if it could be busted cv joint......... It lunged forward so I know at one point it could move forward but ever since I tried to jam it in first now car wont move and stalls in neutral
Old Nov 23, 2015 | 03:11 PM
m4xwellmurd3r's Avatar
I think you broke it.
Old Nov 24, 2015 | 04:20 PM
stc876's Avatar
Default Re: 02 crv new clutch stalls in neutral wont drive
Think I broke the transmission or are you being a smart *** because I'm looking for real help.... I found a transmission for 250 and started pulling the motor to inspect
Old Nov 24, 2015 | 11:18 PM
no, the transmission. You tried forcing it into gear when it clearly didn't want to. that's the fastest way to break a gearbox. you NEVER try to force a transmission to go into gear. if it doesn't go in with a simple wrist flick then something is wrong. it sounds like you have two gears trying to engage at the same time. when the car is off can you shift gears?
Old Nov 25, 2015 | 05:51 AM
v4lu3s's Avatar
RTFM
i doubt trying to force it in once broke it, unless it was on teh verge of failure anyway. I would inspect your linkage at least first. does it shift through the gears with the engine off at least? or fell like it does?
Old Nov 25, 2015 | 07:35 AM
stc876's Avatar
Yeah I would have to agree with Ya it wasn't my finest moment
Old Nov 25, 2015 | 07:38 AM
stc876's Avatar
Transmission had 370000km on it... It was bone dry on fluid for God knows how long... It was always hard to get into secound.....
The linkage is fine it feels like it shifts into every gear fine while running or not exept reverse won't go in
Old Nov 25, 2015 | 05:04 PM
v4lu3s's Avatar
RTFM
yeah if you ran it dry might as well replace it now then...
Old Nov 28, 2015 | 09:20 AM
stc876's Avatar
With no pressure applied... Does that look recessed back far enough???
[I]any problems you can see with this??[/I
Thanks in advance if any one can give me some advice
Old Nov 29, 2015 | 02:53 PM
Yeah, that looks pretty normal. I would wipe off that purple grease stuff though. it'll end up flinging out onto the friction plate otherwise.
Old Dec 9, 2015 | 12:02 PM
stc876's Avatar
Okay so I put a new tranny in it and it drives forward now but I don't think the clutch is fully disengaged it burns with the clutch in and lunges a tiny bit on start up... It also won't come out of first and now I'm affraid to pull it out of 1st
Old Dec 10, 2015 | 01:14 PM
stc876's Avatar
Okay so I tried to stall the car in first gear and it immediately popped out of first and did not stall... But now it goes in to any gear but reverse and releasing the clutch does nothing at all
Old Dec 10, 2015 | 02:01 PM
stc876's Avatar
Okay I just noticed the speedo was climbing with the gas so I'm going to double check axels tomorrow but still wierd that I can't get it into reverse Any ideas?? That's two different transmissions nether will go into reverse
Old Dec 14, 2015 | 02:55 PM
stc876's Avatar
Axel was out put it in and it drives and I have reverse but clutch doesn't disengage.... I changed master and slave cylnder and while bleeding I watched a hole stroke of fluid release throu boot on the slave cylnder... The slave cylnder still moves is it broken now?
Any help would be great appreciated
Vinde
Oct 23, 2014 11:42 PM
snoopaloop986
Jul 17, 2013 02:55 PM
jdmcivicracer89
21
Jun 5, 2008 09:39 AM
dyases
Nov 30, 2003 09:25 PM
brucie
Jul 12, 2003 11:23 AM
