Honda CR-V & Element 2WD & 4WD Element & CR-V
Engine knock when in gear [video] [2009 CR-V 4WD]
Old Nov 22, 2015 | 07:17 AM
RA022626's Avatar
Icon5 Engine knock when in gear [video] [2009 CR-V 4WD]
We have a 2009 CR-V 4WD that was recently purchased as-is from a Toyota dealer, almost 100k miles. I've changed all the fluids, including switching the oil to Mobil 1 full synthetic and a Honda filter.
From the very beginning, I've noticed a knock/rattle that occurs constantly, whether the engine is cold or warm. I always hear it clearly inside the car while we're driving.
But it only seems to happen when the car is in gear. If it's in park or neutral, the sound seems to go away.
I tried unplugging spark plugs (while in gear) to see if it was one particular cylinder, but the sound seems to go away when I unplug any of the spark plugs (hard to tell with the rough engine).
In this video, the car starts out in park, then switched to reverse, then back to park.
Any ideas about the cause?
Thanks!
Old Dec 4, 2015 | 12:08 PM
H22A EG6's Avatar
Default Re: Engine knock when in gear [video] [2009 CR-V 4WD]
sounds like the valve lifters need to be adjusted
this is regular manitnece
typically there is little risk with this from what i hear
I think Honda service will do this for like $180
scifiballer24
Mar 4, 2011 04:50 PM
HGZ
Aug 10, 2009 11:51 PM
xkrntamax
Honda Civic (2006 - 2015)
18
Feb 27, 2009 10:04 AM
aries331
Nov 20, 2007 04:18 AM
93coupeDX
Jan 7, 2004 08:09 AM
