91 civic hatch..starts bucking/code 1 not staying gone
Old Nov 21, 2015 | 10:18 PM
mikeyindigo's Avatar
Default 91 civic hatch..starts bucking/code 1 not staying gone
alright so i just bought this ef and did a thurough tune up with the exception of the fuel filter (couldnt get the left 17mm off, filter kept spinning)
heres what the car is doing..
starts up everytime but once it gets warm, it wont go over a certain RPM (cant see which RPM it starts at, DX Model) in any gear. it starts to buck really bad and really only wants to move at WOT in any gear (with its mighty 65hp haha).
now, it was throwing a code 1 so naturally, i replaced the O2 Sensor with a Bosch unit from Autozone along with the tune up bits.
i reset the ecu via the negative battery cable (left it off for about 15 seconds) and drove it after. at first, the code didnt appear, although it was still doing the RPM/Bucking thing. I drove it again, later in the day and the CEL came on and it was still doing the RPM/Bucking thing.
From what i have already read, the ECU omits O2 readings at WOT but i've replaced the O2.
Contrary to that point, i also read Hondas dont really care for Bosch O2 sensors. is this true? if so, i will order an OEM sensor.
so my question is the above and also, is the bucking/RPM issue caused by the O2, in theory? or could it be the fuel filter also?
Thanks dudes..
Old Nov 22, 2015 | 09:16 AM
bigtimegambler's Avatar
Default Re: 91 civic hatch..starts bucking/code 1 not staying gone
In my ef I had the same issue, then I replaced the fuel filter. Little to no bucking now. Also something to consider though, replace the cap and rotor. Very cheap, might help you too. As for the o2 sensor I think it is wise to use an OEM o2 sensor.
Old Nov 22, 2015 | 11:16 PM
netfreak's Avatar
Check your ignition timing too. I had a similar issue from the sounds of it when the revs were around the 2500 range. My timing was way advanced and everything seems fine now after adjusting.
Old Nov 23, 2015 | 08:07 PM
i cannot beleive i forgot the cap and rotor lol thanks for that! replaced the fuel filter, waiting on the denso O2 from autozone (special order, comes tomorrow).
will check the timing once i get the O2 and cap and rotor in, thank you for the help! and yeah mine sounds like its in the 2500-3000 range but i cant be sure, the exhaust is stock and DX cluster doesnt help lol..
thanks again guys! will post back when i get things put on!
Old Nov 24, 2015 | 02:22 PM
havent replaced the cap and rotor yet but its still giving me a code 1 and idling funny/high..could a vaccum leak or cap/rotor cause it to run weird and throw a code 1 (o2 sensor). The O2 is now a Denso unit.
Old Nov 24, 2015 | 06:59 PM
So its throwing the same code with the OEM style o2 sensor.... Could be a wiring issue to the o2 sensor then. Have you tried resetting the ecu?
Old Nov 24, 2015 | 07:04 PM
yes with the oem sensor. I forgot to reset the ecu
I'll try that along with the cap/rotor and see!
Old Nov 25, 2015 | 07:26 PM
asianflava's Avatar
Had the same problem and it was the Ignitor.
Old Nov 26, 2015 | 12:55 AM
ugh guess ill get that too lol cars gonna be brand new fairly fast haha
Old Nov 27, 2015 | 06:05 PM
FIXED:
the O2 - Cap/Rotor - Fuel Filter fixed it...
now...what can we do about my high idle? lol..theres no super obvious vacuum leaks..it idles at ~1500-1800 when warm and sometimes wonders..
thinking my iac is dirty? i cleaned the tb and no change..
Old Nov 27, 2015 | 06:18 PM
If you have no surging adjust your throttle cable. If it's too tight, it would leave the throttle partially open and keep the revs in that range. I would know because this happened to me.
Old Nov 27, 2015 | 10:16 PM
it is surging :/
Old Nov 27, 2015 | 10:30 PM
Yeah try and clean the idle air control valve and report back
Old Nov 27, 2015 | 10:32 PM
will do tomorrow..thank you! :D
SlowB20z
Engine Management and Tuning
Dec 28, 2012 09:12 AM
SpoolinEK9
Dec 13, 2010 05:24 PM
Elbowpunk
Feb 3, 2006 06:50 PM
awdvr6
Mar 12, 2004 10:36 AM
S13 slide
Jun 2, 2002 03:30 PM
