d16y8 swap no fuel
Old Nov 20, 2015 | 06:34 AM
lewismayo's Avatar
Default d16y8 swap no fuel
Hey guys. I am working on getting a y8 swap going in my previously running y7 1998 civic. I'm working with an automatic engine and harness on my old manual transmission. The car will crank but I am getting no fuel at the fuel rail. I have tried both the automatic and manual y8 ecu and neither one is helping. I read online that a thermostat housing ground wire could be the cause but I can't even find ground wire on my harness to connect.. Any ideas would be appreciated.
Old Nov 20, 2015 | 11:42 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: d16y8 swap no fuel
Was this harness previously working, or did you get it from someone else? There's ground wires there, you just have to look harder. The junk yard harness I used for my swap, the bolt ring for the ground had been cut off, and I had to cut and solder a new one on, but the wires are definitely there.
Old Nov 20, 2015 | 04:06 PM
HondaPartsHero's Avatar
Technical Hero
What year is the new engine and harness?
Old Nov 21, 2015 | 10:02 AM
Former User's Avatar
Thermostat ground = G101
Also check fuses 13 and 44.
Old Nov 21, 2015 | 07:28 PM
bigtimegambler's Avatar
If all else fails, start with another d series harness
Old Nov 23, 2015 | 01:43 PM
lewismayo's Avatar
I found that my ground cable was already hooked up........
Any other reasons that my engine wouldn't be getting fuel with the swap?
Old Nov 23, 2015 | 01:49 PM
NotARaCist's Avatar
Is the CEL on? Does it work?
Old Nov 23, 2015 | 03:02 PM
lewismayo's Avatar
No check engine light.
the gauge cluster does seem to be functioning normally, yes.
Old Nov 23, 2015 | 03:05 PM
NotARaCist's Avatar
So when you turn the key to ON(II), the CEL comes on for 2 seconds, then turns off?
Old Nov 23, 2015 | 03:18 PM
lewismayo's Avatar
No. My CEL does not come on.
Old Nov 23, 2015 | 03:36 PM
NotARaCist's Avatar
Then either your CEL isn't working, or you have a deeper issue. Pull the cluster, make sure the bulb is there, and make sure it isn't blown. Do you own a voltmeter? We're gonna have to dive into your main relay.
Old Nov 23, 2015 | 05:55 PM
joey1320's Avatar
Fail
Old Nov 24, 2015 | 08:24 AM
lewismayo's Avatar
Just checked and the bulb is still good.
I do own a voltmeter.
Old Nov 24, 2015 | 08:34 AM
So now the CEL works but didn't previously?
Old Nov 24, 2015 | 09:02 AM
lewismayo's Avatar
No. The CEL light does not come on but a faulty bulb is not the reason.
Old Nov 24, 2015 | 09:04 AM
The CEL doesn't work. Check for cut CEL wire.
You need a working CEL.
Old Nov 24, 2015 | 09:33 AM
lewismayo's Avatar
I found no cut wires behind my cluster. I'm not sure where else to look for a CEL wire.
Old Nov 24, 2015 | 09:46 AM
Jimster480's Avatar
Have you tried jumping the 2p connector under the passenger dashboard? It is near the bottom by the ECU.
If you jump this on an OBD2 car the CEL will just straight come on.
If you do this and it still doesn't work then its possible that the harness itself is bad.
Inspect the ECU Plugs to make sure there are no damaged wires.
Once you turn the car to On II use your Volt Ohms meter to check the power to the MAP sensor & TPS, both of these should have power (IIRC 5V) even when the car is not running but the Ignition is on ON II.
Old Nov 24, 2015 | 01:19 PM
existanzcivicb20's Avatar
Question can you hear the fuel pump prime when you turn the key to the on position (key on engine off)
Also make sure when you connected the ECU by the passenger side you also connected the 2 GREEN connectors that are above or to the side of the ECU.
If the fuel pump is not working the CEL is not coming on it sounds like a ground issue. Make sure you have all the main grounds on valve cover, Thermo housing, Throttle body, Trans ect
Old Nov 24, 2015 | 04:53 PM
Jimster480's Avatar
If he bought the harness from someone its also possible that the harness is bad/damaged.
Cody Griffin
Mar 10, 2018 12:48 PM
HotrodHooptie
Jan 6, 2018 02:59 AM
HondaNooby24
24
Aug 18, 2013 04:54 PM
redturbo0
May 15, 2013 06:02 AM
