Gap when closing hood
Old Nov 19, 2015 | 08:09 PM
Black_89's Avatar
Default Gap when closing hood
So I bought my 99 Civic Si with a black not OEM hood, found a perfect OEM Milano red one to replace the black one but there is this gap that I can't seem to get all the way gone when shutting.
I've tried screwing the rubber stoppers on each side above the headlights. And have adjusted the assembly where it latches.
Any other suggestions...
Pictures attached.
Old Nov 19, 2015 | 08:15 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Gap when closing hood
Uh, that hood is still open. The security latch isn't catching.
Old Nov 19, 2015 | 09:10 PM
Neth's Avatar
yeah, it looks like you need to bring the assembly up so it catches on the second latch and stays down.
Old Nov 19, 2015 | 09:25 PM
Black_89's Avatar
Bring it up to close the gap? The hood won't open unless I pull the realese so I know it's not open. But I will mess with it tomorrow.
Old Nov 20, 2015 | 02:42 AM
joey1320's Avatar
Every locking mechanism I've dealt with has two positions for the latch to lock into.
Your hood seems to be latched onto the first spot and now you have that gap. If you can't get the hood to close any further, even with a good amount of force behind it, then bring the locking mechanism up, so the second position is reached.
Old Nov 20, 2015 | 07:56 AM
Black_89's Avatar
So I've raised the hood latch assembly and this is the new gap that I'm left with ..
Old Nov 20, 2015 | 08:32 AM
eghatch9295's Avatar
Stancetard Hate Monger
lower it.
Old Nov 20, 2015 | 08:52 AM
joey1320's Avatar
Open the hood and secure it.
Take a pocket screw driver and presss down on the hood lock and see how many locking positions you have. You should have two.
If the lock doesn't have two positions, you should replace the latch assembly.
Old Nov 20, 2015 | 08:53 AM
joey1320's Avatar
Can you post a picture of the lock assy?
Old Nov 20, 2015 | 02:41 PM
Black_89's Avatar
I was able to get it to click twice so it's not broken. But I did lower it again and cleaned the latch assembly so I'll take pictures when I go back out to show how it sits now after I lowered it back down.
Old Nov 20, 2015 | 03:36 PM
Black_89's Avatar
Old Nov 20, 2015 | 03:38 PM
NotARaCist's Avatar
That's exactly where your hood would be sitting if it wasn't latched at all. Let's see some pictures of the latch, and the hammer (the part of the latch that's bolted to the hood).
Old Nov 24, 2015 | 08:28 AM
Black_89's Avatar
That's exactly w
Old Nov 24, 2015 | 04:57 PM
see the problem?
Old Nov 24, 2015 | 06:27 PM
Black_89's Avatar
Originally Posted by eghatch9295
see the problem?
I don't... Do you ..?
Old Nov 24, 2015 | 06:33 PM
White_EG1's Avatar
I do
What part of WA you in op? Ill fix it, but you gotta dab me out
Old Nov 24, 2015 | 06:44 PM
Black_89's Avatar
Originally Posted by White_EG1
I do
Haha that's awesome I'm in Bremerton. And what's the problem! I don't see it lol
Old Nov 24, 2015 | 07:01 PM
White_EG1's Avatar
It's the latch. I don't think there's pick n pull up there I could pull you one and bring it down
Old Nov 24, 2015 | 07:09 PM
Black_89's Avatar
There's one in Poulsbo the Yank A Part but they only have 1 00 civic up there need to go check but I heard about one in Belfair that's mostly Hondas but I'll let you know. What part of the latch is broken?
Old Nov 24, 2015 | 07:42 PM
its closed. you've been driving around on the secondary only. i STRONGLY recommend securing it with a ratchet strap or similar until you can fix it properly.
Old Nov 24, 2015 | 08:32 PM
NotARaCist's Avatar
74120-S01-A04 024 001 LOCK ASSY., HOOD (KTM LOCKS) 49.87 34.41
It's freaking $35 brand new. Just get a new one from Majestic and call it a day.
Old Nov 24, 2015 | 09:27 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Why not use a screwdriver in the latch, pull the hood release, and pop the latch open?
And if that doesn't work the problem wouldn't be with the latch, but somewhere back up the line.
EDIT: I don't think that latch is closed. It may not be closing though. Use a screwdriver to verify it's proper operation first.
eH.
Old Nov 24, 2015 | 09:48 PM
Black_89's Avatar
eH.
I did the screwdriver test and got it to click twice, that's why I'm confused on why it's not closing the gap when I shut the hood
Old Nov 24, 2015 | 09:55 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Where is the hood "hook" sitting when it's closed? In other words, is the hook matched up with the latch or is it resting on a part of the body?
I'm not familiar with your model, but maybe you can pull the grill and see what it's doing/not doing when it isn't locking.
EDIT: hook = hammer. I was unsure of the correct terminology.
eH.
Old Nov 24, 2015 | 10:04 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
It looks like the engine-side of the hood "hook" might be landing on the aft part of the body. There's quite a bit of red paint missing.
Maybe the hood is about a quarter inch too close to the windshield?
eH.
