Read EK4 P2T OBD2 Ecu? With Pictures
Old Nov 19, 2015 | 09:01 AM
creizlein's Avatar
Default Read EK4 P2T OBD2 Ecu? With Pictures
I have a 1998 Civic VTi EK4 JDM which has the factory P2T OBD2 ecu, but, as expected it doesn't have any standard OBD2 pinout to plug a scanner and read data.
Below you can see the two plugs that come out of the ecu, the standard 2 wire diagnose one and the 3 cable with +12v and signal
I bought a cable adapter that converts the 3 cable out from the ecu to a OBD2 plug and I am trying to read some data out of it without any luck.
For Honda 3pin male to female 16pin obd2 diagnostic cable
The intention is just to READ data out from the ecu, not change anything, but at least be able to read error codes and engine details like rpm, lambda sensor and such. Basically i want to use some "Torque" alike Android app.
Does anyone have accomplish this or know what is the protocol that the scanner needs to support in order to read this ECU? So far I have tried with two different types of scanner, one is just the classic EML327 Bluetooth dongle and the other is a MaxiScan MS310 which is what i have in stock at home.
Below are the pictures of the ECU and the scanners I used, they do come to live (start and turn on, so voltage is coming trough, but upon scanning it doesn't detect anything with the various protocols it tries)
Old Nov 19, 2015 | 09:24 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Read EK4 P2T OBD2 Ecu? With Pictures
The OBD2 diagnostic connector should be located next to your fuse panel under the dash.
Old Nov 19, 2015 | 11:04 AM
creizlein's Avatar
No, there is no obd2 connector for sure, its a well know issue with these JDM EK4 models, its not the same as EM1 which came with it...
Old Nov 19, 2015 | 11:07 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
Can you take a picture of your fuse panel area, under the dash? I'm genuinely curious as to what you have then. Disregard the text on the picture aside from the obd2 port, I just grabbed something off google for reference.
Like this :
Old Nov 19, 2015 | 11:10 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
Actually quick research shows that you are correct, there may not be an obd2 port.
What data are you trying to read?
*edit*
Just monitor data?
Old Nov 19, 2015 | 11:36 AM
creizlein's Avatar
The big difference is the market, this is not an USDM car, my VIN number doesn't even exist there and it was made for Europe as it looks like by the ECU code, but its JHM* vin code... and as you saw there is no obd2 connector near the fuse box, believe me, i wish there was, hehe
I'm not trying to read anything specific but everything it throws up, im more curious in getting some generic Torque-Android app to read rpm, lambda sensor, error codes if any, and so on.
I know its possible but just unsure of what scanner type has to be connected to it, clearly its not a generic one.
Old Nov 19, 2015 | 11:44 AM
Juako Iraola's Avatar
I think you should post some pictures of ur fuse box just to be sure.... :D
Old Nov 20, 2015 | 12:15 PM
tony_2018's Avatar
Fish Twig
0bd2 scanners, like one you posted, do not read jdm ecus
Old Nov 20, 2015 | 12:23 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Is he stuck with the old school way of having eleventybillion gauges then?
Old Nov 20, 2015 | 12:30 PM
creizlein's Avatar
So which type of scanner do i need to get? thats my point, i need to know what protocol or type the scanner has to be in order to read it.
I know its possible because I saw scanners reading the ECU, but just cant get my hands on them to check which type they are.
Old Nov 21, 2015 | 01:03 AM
tony_2018's Avatar
Fish Twig
From what I've searched on my jdm obd p2j-j11, it still runs obd1 protocol.
Old Nov 21, 2015 | 05:48 AM
creizlein's Avatar
So a obd1 scanner will do the trick? is there anyone you can recommend out there? like these bluetooth dongle style or usb?
gsrekrevs210k
Engine Management and Tuning
Feb 21, 2011 11:43 AM
ALLMOTORJ
Feb 27, 2004 11:48 AM
