wire tuck gone wrong.
Old Nov 18, 2015 | 05:09 PM
Quentin Zach's Avatar
Default wire tuck gone wrong.
So I did a wire extension and tuck but one of the plus I cut off did not make is way back onto the car I cannot find where the other end of the wires are I think it might have something to do with headlights considering mine don't work. But the car is a 92 civic vx Canadian model. There are 5 wires. Black/yellow, white, blue/red,yellow, black/red
Old Nov 18, 2015 | 06:50 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: wire tuck gone wrong.
That sounds like the A/C wiring. Fixing that plug will not correct the light problem.
Old Nov 18, 2015 | 07:57 PM
bspeed's Avatar
multimeter, etm and a legal pad to write down tested circuits.
Old Nov 18, 2015 | 09:48 PM
It's a vx stock with no a/c or power steering it's also not the 0/2 plug although it does plug into the 02 sensor
Old Nov 19, 2015 | 07:13 AM
My turn signals and hazards still work so I don't know if it has anything to do work the hazards or not. It's not on my Chilton wiring diagram
Old Nov 19, 2015 | 12:58 PM
cre8ive's Avatar
Where did the other end go? Did you remove anything in the process?
Old Nov 21, 2015 | 08:33 AM
I beleive the other end was on one of the shock towers but now is in the passenger fender well. I just need to know where the other end of the wires might be
Old Nov 21, 2015 | 10:01 PM
I also noticed my blower motor isn't working could this be the blower motor wiring
Old Nov 22, 2015 | 03:02 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If the car did not come with A/C, then this plug would not be plugged into anything. The A/C compressor, dryer pressure switch and condenser fan relay/switch sub harness would plug into the 8-pin plug that you pictured. It would simply be mounted on the frame rail just behind the passenger side headlight. Usually, it is capped by a white end plug that has a "C" shaped clip on the bottom to locate the 8-pin plug over the wire loom of the headlight/parking light/horn harness. Many times, these are missing and the 8-pin plug is simply open.
Old Nov 22, 2015 | 06:41 PM
But I have the other end of the plug? I just don't know where the other end of the wires are
thrasher324
Dec 28, 2016 01:59 PM
$amGD3
Audio / Security / Video
14
Jun 8, 2011 08:55 AM
JDMb18c1HATCH
Mar 11, 2011 09:39 PM
FlewByU352
Mar 14, 2010 05:58 PM
jbell
Apr 23, 2005 02:44 PM
