D15B7 engine tapping out at 5500rpm at WOT
Old Nov 17, 2015 | 12:10 PM
Sic_DA_Nine's Avatar
Default D15B7 engine tapping out at 5500rpm at WOT
1995 honda civic dx
5 speed manual
d15b7
no cel
having a problem when the car is at wide open throttle
it bounces off a limiter aat 5500 rpm.
if im not at wide open throttle, it will climb pass.
anyone have this issue?
Old Nov 17, 2015 | 12:47 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default re: D15B7 engine tapping out at 5500rpm at WOT
Have you ever messed with the TPS?
Old Nov 17, 2015 | 04:38 PM
tamboo's Avatar
10 Year Member
https://honda-tech.com/honda-crx-ef-...hread-2830131/
Old Nov 19, 2015 | 01:31 PM
never messed or removed the tps
i did check the voltage of the tps and everything seems to be good.
5v switched igntion
and reads 4.48 at wot
Old Nov 21, 2015 | 05:56 AM
Former User's Avatar
FYI - The P06 ECU fuel cuts at 5800 rpm.
How high?
Does the CEL work?
Old Nov 21, 2015 | 09:41 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: tapping out at 5500rpm at WOT
That doesn't ring true with what I've experienced on my P06 D15B7. Just today, 4th gear, 6300 RPM and climbing just before shifting to 5th, multiple times. If it was cutting the fuel off, I don't see how the RPM would continually climb. I know the dash tach isn't 100% accurate but 6500 RPM isn't that high either to believe the tach is off that large of an amount.
Also why would the fuel cutoff be set 700 RPM lower than the rev limit of 6500 RPM (which I have hit on flat lands)? 2nd gear rev limiter on occasion, doesn't seem to stop pumping fuel prematurely.
Maybe I'm not understanding how fuel cutoff works for the high rpm.
Old Nov 21, 2015 | 10:56 PM
Default Re: D15B7 engine tapping out at 5500rpm at WOT
Have a debate with the service manual:
Old Nov 21, 2015 | 11:26 PM
NotARaCist's Avatar
I never narc'd on nobody!
Old Nov 22, 2015 | 07:25 AM
94EG8's Avatar
Seagull Management
The service manual is wrong. Fuel cut for a D15B7 is around 6500 - 6800rpm.
Old Nov 22, 2015 | 07:31 AM
Ah, typo. Just curious, how do you know? Did Honda publish a correction?
Old Nov 22, 2015 | 07:39 AM
94EG8's Avatar
Seagull Management
They may have. I owned a bunch of those engines. Redline on the factory tach is 6400rpm and it's always lower than the fuel cut. I know the factory tach isn't very accurate but they'll usually go close to 7000rpm before they hit the rev limiter.
Actually, I think the fuel cut for D15B7 and D15B8 are reversed in the service manual.
Old Nov 22, 2015 | 05:50 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Not looking to debate, looking for some understanding on how the fuel cut works as it must not be plainly obvious if it's at 5800 rpm and yet the car continues to accelerate steadily with no loss in torque beyond that to 6500 range.
That's not the only error in the manual for the D15B7. There is gross errors on the main journal sizes not even printed as well as a misprint for rod big end size etc.
Thank you for confirming my suspicions. The other option was simply I didn't understand how the fuel cut operates as the assumed operation that comes to mind would prevent any further RPM climb without a noticeable change in torque.
Old Nov 24, 2015 | 11:51 AM
How high?
Does the CEL work?
CEL does work
jumped the pins also just in case i had a code, but no code present
at partial throttle, i have brought it up to about 6500 and let off right before the redline on a dx cluster.
Old Nov 24, 2015 | 12:13 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
CEL does work
Does it (the motor) sound the same just before you cut it off at 6500 partial throttle as it does when you get the automatic cut at 5500 rpm wide open throttle?
Old Nov 25, 2015 | 03:08 AM
crazyhorse2011's Avatar
10 Year Member
Loved
My d16z6 would read 8000rpm and the fuel cut wouldn't happen.
Put in an Omni Power OEM replacement tach, tried again, rev limiter at 7400 rpm.
pityocamptes
Dec 5, 2015 05:56 AM
B_Swapped93
Dec 17, 2014 07:16 AM
FLDAX
Feb 27, 2008 09:54 PM
JasonST
Feb 7, 2007 07:58 AM
curiousgpnoy
May 10, 2004 07:50 AM
