No crank
Old Nov 8, 2015 | 07:52 PM
Steven Fuston's Avatar
Default No crank
Originally Posted by 92EG8
To answer above posters... Changed starter was tested and works ...WILL start if i jump the battery to the spade female plug on the starter also the only thing i see is a black oval switch that goes in and out by the clutch pedal looks good there... also where can i locate the Starter Relay i have a 95 Coupe EX ...The PGMFI works fine if not fuel pump wouldnt prime...correct?
Hey what ended up being the solution to this cause my car is currently doing the same thing. It's a 95 civic with a swap. Won't crank at all unless jumped to the spade female connector. I need to figure this out.
Old Nov 8, 2015 | 08:39 PM
Former User's Avatar
Default Re: No crank
Post the swap info.
Manual transmission?
Old Nov 8, 2015 | 08:51 PM
Auto to manual. B20 low comp ls trans. Brand new starter brand new battery brand new alternator fuse box relocated under glove box and battery is in the trunk. When I jump the signal wire to the hot on the starter it cranks. When I turn the key it does nothing. Before it stopped all together it had a delay sometimes. Sometimes it would fire right up. But mostly the key would trigger the starter but the starter wouldn't turn for a few seconds some times up to ten and once up to almost 30 second of me just holding the key. Now it won't crank at all.
Old Nov 9, 2015 | 04:37 AM
Focus here.
Johnboy0620
Oct 20, 2018 10:12 AM
Eversonc85
Jul 5, 2015 09:13 AM
tubbierainbows
Apr 14, 2014 10:06 PM
ramswood2000
10
Sep 27, 2010 05:20 AM
TylerC161
Oct 5, 2006 05:45 PM
