Steering wheel shaking at 70 mph and over
Old Nov 8, 2015 | 04:35 AM
whiteformula98's Avatar
Default Steering wheel shaking at 70 mph and over
Hi all. I just replaced the CV Axles, inner and outer tie rods, front wheel bearings, brake pads and rotors on my 99 Civic VP. I took it to the local Goodyear for an alignment and had the Mechanic check over my work to see if everything was good and tight. He said everything looked nice and tight. The steering wheel will shake at 70mph and over but funny thing is that it isn't a constant shake, sometimes it goes away for 20 to 30 secs and then comes back. Advice on what to do?
Old Nov 8, 2015 | 04:54 AM
TheShodan's Avatar
Moderator
Default Re: Steering wheel shaking at 70 mph and over
Tyres..not just wear pattern but radial belt may have shifted. Try tyre rotation to test to see if that is a possibility too.
Old Nov 8, 2015 | 11:10 AM
NotARaCist's Avatar
I never narc'd on nobody!
Or it could be something as simple as needing a tire balance. As Shodan said, rotate your tires and see if the vibration moves with the tires.
Old Nov 8, 2015 | 02:39 PM
tony_2018's Avatar
Fish Twig
You must've hit alot of pot holes, tires need to be balanced. Look into road-force balancing.
Old Nov 8, 2015 | 06:19 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If your rotation doesn't change anything, I'll be keeping an eye on this thread.
I've had a wobble since I've owned my hatchback which hasn't changed with 4 sets of tires, 3 sets of rims, 2 new axles. My next steps is new upper control arms, new wheel bearings, new lower ball joints, all new bushings, and new inner and outer tie rods. At some point I hope to get rid of the wobble. Besides, the car really could use a whole new front end as it's all 20 years old.
Old Nov 8, 2015 | 06:22 PM
NotARaCist's Avatar
Wobbles and vibrations are diagnostically different, TomCat.
Old Nov 8, 2015 | 06:28 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
True but OP did say the steering wheel shakes at 70 MPH (same as mine). This to me is more in line with a wobble over a minor vibration.
Old Nov 8, 2015 | 06:44 PM
NotARaCist's Avatar
Eh, I get where you're coming from, but that's not the case. "Wobble" is generally a loose feeling in the steering components, sometimes with forced input (bump steer), and is generally caused by a poor alignment or failing suspension components (primarily rubber parts). Shaking is a feeling in the steering wheel or body of the car, never with forced input, and is generally caused by bad balance, or improperly worn tread.
It might seem like semantics, but diagnostically, the difference is very important.
Old Nov 8, 2015 | 07:47 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Hmmm okay. Methinks I need you to come to BC and tell me what mine is.
I know I'm at a loss.
Old Nov 9, 2015 | 06:27 AM
Former User's Avatar
Sounds like good advice.
Old Nov 9, 2015 | 06:49 AM
unuselectus's Avatar
I'm very interested to see what the issue is. I am having a "wobble" issue with my civic as well.
I'm assuming that I need to replace my axel, but I bought the car and the power steering was no connected. I think I might have multiple issues. I need to understand what affects the steering and what doesn't.
Old Nov 9, 2015 | 06:58 AM
Please create your own thread.
bsmith100
Mar 10, 2010 01:10 PM
SPOOLINmatt
May 29, 2008 11:16 PM
ShadyBAB
Jan 13, 2006 05:58 PM
crxaddikt
Feb 10, 2004 08:55 AM
i_krayzie_i
Apr 6, 2002 08:04 AM
