96 Civic ELD & O2 Codes
Old Nov 7, 2015 | 07:55 AM
TNight's Avatar
Ran my scanner and pulled codes referencing the ELD and 02 read the TSB but fuse 15 is not blown . I have changed the 02 Sensors and the ELD fuse.
The only thing I haven't done is found the wire that touches the intake and causes the malfunction. So my question is do I need to remove the intake or can I get to it from the bottom as I am unsure of the exact location?
Thanks
ok so I'm looking at the fuse box for this fuse 15 again dbl checking everything .The car giving me the headache is a 96 EX auto I compare the fuse box to my 98 EX 5 sod and the fuses are in different locations so I found another 98 EX 5 sod and yet again the fuses are a little different so I'm kinda lost in wtf mode .I also was able to get a good look at the wire that the TSB SAYS WOULD CAUSE THE PROBLEM AND There is no freed wire and it is not touching the bracket or Intake. HELP
Old Nov 7, 2015 | 04:39 PM
Former User's Avatar
Default Re: 96 Civic ELD & O2 Codes
Post the OBD2 CEL codes.
Post pics of the fuse boxes.
Old Nov 8, 2015 | 10:34 AM
TNight's Avatar
P0135 O2 Heater Circuit ( Bank 1,Sensor 1
P1298
1 Electric Load Detector (ELD) Circuit High Voltage 2) ELD High Voltage
P0141 )2 Heater Circuit (Bank 1, Sensor 2)
This I show it reads on my scanner
Old Nov 8, 2015 | 11:18 AM
Pics of fuse boxes?
Voltage test installed fuse 15. Both top tabs should be hot.
Old Nov 8, 2015 | 04:45 PM
TNight's Avatar
Old Nov 8, 2015 | 04:47 PM
TNight's Avatar
2 15 amp fuses in top row I installed the 2nd 1 from the left based on the other 2 civics having 1 there
Old Nov 8, 2015 | 06:21 PM
Fuse 15 --> The 15 is the slot location in the fuse box not the fuse amperage rating. The amperage rating of fuse 15 is 7.5A. See diagrams below.
https://honda-tech.com/honda-civic-d...fuses-3079359/
Also, turn the key from the OFF position to the ON(II) position. Does the battery light symbol turn on and stay on in the cluster?
Giantsfan2012
11
Sep 29, 2014 02:35 AM
jcuetizzi
Jan 23, 2013 02:51 PM
mtownsi
Sep 23, 2012 03:48 PM
LB98ekhatch
Feb 2, 2009 10:29 PM
Stock@$$GSR
Apr 5, 2007 05:23 PM
