91 sedan jerk around 1500 rpm
Wife bought a 91 sedan a while back with a dohc zc just replaced timing belt idles good drives good except for there's a slight jerk in 1st around 1500 happens for a split second. If you ease into the gas slowly doesn't seem to be there any ideas?
The FITV is the fast idle thermo valve. It should be located on the underside of the throttle body. Does your car have any weird idling problems?
Did you check the fuel filter?
