LSv dowel pin fitting issue
Old Nov 5, 2015 | 10:21 PM
LSvEKhatch's Avatar
Default LSv dowel pin fitting issue
I have b18b block that was shaved and b16a head that was shaved twice.. Do i need to shave dowel pins accordingly or not?
Old Nov 6, 2015 | 11:44 AM
kevinsmachine's Avatar
Default Re: LSv dowel pin fitting issue
Should be fine
Old Nov 7, 2015 | 03:06 PM
PyroProblem's Avatar
You could always measure the height of it in the block and then in the head. Figure in your HG thickness if you wanna be exact. Trim if needed.
Old Nov 9, 2015 | 04:47 AM
LightningTeg's Avatar
Community Builder
Doubt it. Its a loose fit anyway
Old Nov 10, 2015 | 07:33 AM
crazes's Avatar
Moderator
you would have needed a large amount shaved for it to actually require changes to the dowel pins. You will be fine, but if you want a warm and fuzzy measure it out.
Old Nov 13, 2015 | 12:03 AM
LSvEKhatch's Avatar
I measured it, should be 100% fine, put the head on and started putting arp washers on when realised im missing two washers :/ guess im calling around trying to find a dealer to sell me two.
Old Nov 22, 2015 | 06:54 PM
ojasia's Avatar
Make sure you use the ARP lube with them as well.
d3nn311
Apr 10, 2013 08:16 AM
CHEESEYeg6
May 29, 2012 08:26 PM
Brian_92GSR
Oct 6, 2002 08:21 PM
ultraspeed2nr619
Oct 20, 2001 01:21 AM
