D15B1, where is the knock sensor?
Old Nov 4, 2015 | 05:01 PM
Yuta's Avatar
Default D15B1, where is the knock sensor?
Hello guys,
I am going to do engine swap on 91 civic (D15B1). I am trying to disconnect sensors on the engine so that I can take it out.
So basically, if I understand it right:
Two prong sensor on the side of head=>Coolant temp sensor
One prong sensor on the side of head=>Coolant temp sending unit
Two prong on the back of block=>Fan switch
One prong on the back of block=> oil pressure switch
Quesions:
1. where is the knock sensor? It does not have it?
2. How to take off the wire off the two prong sensor on the back of block (fan switch). It is so tight, can't even get the rubber boot off. Any technique to take it off? Worst case scenario, I will have to cut the wire
Old Nov 5, 2015 | 06:36 AM
v4lu3s's Avatar
RTFM
Default Re: D15B1, where is the knock sensor?
1. Afaik only vtec engines have them.
2. Pull harder.
Old Nov 5, 2015 | 12:16 PM
jlicrx's Avatar
if you are swapping to an OBD1 or OBD2 engine, they have the fan switch on the thermostat housing, with a different connector - you would need to cut the wires, in that case, to swap on the different connector
Bic1090
11
Feb 1, 2012 05:45 PM
sleepingciv
Nov 2, 2008 08:14 PM
orioncivic
Sep 3, 2008 07:50 PM
DC_Legacy
May 29, 2008 03:47 PM
R6Boy69
Jul 5, 2003 02:51 PM
