97 Civic HX - stripped valve cover bolts and head
Hello I'm new on here I have a question I got my valves adjusted on my D16y5 which is a 97 Honda Civic HX sohc they messed up my valve cover bolts and my head they stripped 2 so now it only holds by 3 bolts if I was to swap my head out with a y8 vtec head will everything still work the same or is there any thing I will have to change please help me out Thank you
No they the bolts that go for the valve cover well it's actually the head that got stripped not the bolt so my valve cover doesn't torque down tight 2 of the bolt don't grip the head I pulled them out and the treads are good but the head is trash now
Your vtec-e won't work anymore, which is the whole reason for the HX, fuel economy. I had this happen before as well, I got it fixed by a great technician who used heli-coils or it could've been time-serts, I know it was Honda uses.. into the bad threads and it is holding very well!
If I do a mini me all I have to do is swap ecu stock Y8 ecu swap head with a Y8 then dizzy and cap and that should be it cause I will have to replace the gaskets anyways or am I missing something ?
the whole point of the hx is to keep it eco and good mpg. I foresee you simply trying to do a couple things for more horsepower and running into a major headache. even if you swap in the head you will still have the hx transmission which has much different gear ratio then the ex model. so you would probably want to change your final drive or get an ex tranny. i would personally make an eco car and not dog it out. those cars are getting and rarer and eco ppl are looking for those hx models in decent shape. preferably without leaky pistons.....
and someone correct me if im wrong but i was aware the intake manifold isnt the same as the hx so you will probably be restricting airflow which could run the car rich. at least something like that happened on my 91 daily driver
You are entirely overthinking this. Just use timecerts or helicoils, as multiple other people have already told you.
A y8 swap will require you to also require the 5wire o2 sensor to a 4 wire by depinning the wires by the ecu as well.
I'd just fix the threads in the head. I'm working on 40mpg in my 98hx. Thats the beauty of an HX.
x4 on using helicoils, that is a proper repair and honestly valve cover bolts require a low torque spec so there isn't much stress on those threads anyway
Doug684
Sep 22, 2004 05:40 AM
CivicSiRracer69
May 7, 2004 02:21 PM
VXpride
Jul 31, 2003 08:53 AM
