1991 Civic LX No Crank No Start
Old Oct 27, 2015 | 08:31 PM
300k's Avatar
Default 1991 Civic LX No Crank No Start
Hello Honda Enthusiasts...
Quickly, I have a 1991 LX sedan recently having a problem with getting the car to start. Key in ignition, turn key, no crank. All lights and power works, fuel pump etc. New Honda battery. Starter tested fine. Will not crank. Anybody else have this issue?
Old Oct 28, 2015 | 05:39 PM
sr20paisa's Avatar
Default Re: 1991 Civic LX No Crank No Start
check the compression and timing
happened to me when the timing slipped had 6 bent valves and a blown head gasket
Old Oct 28, 2015 | 11:09 PM
300k's Avatar
Did you even read the post? What does compression and timing have to do with a NO CRANK symptom which means when I turn the key, nothing happens.
How did you slip your timing? Don't take this the wrong way but,how do people ruin a Honda, seriously? The only way I can imagine this happened is you put everything back together OUT OF TIME, or you didn't tighten the tensioner, started it up and revved it at 9 grand until it exploded. Not trying to be a doucher.
Old Oct 29, 2015 | 06:42 PM
FOUR-G's Avatar
If you're not getting voltage at the starter solenoid with key in START position, check in this order:
1. battery cable
2. clutch switch (MT) or neutral safety switch (AT)
3. ignition switch
4. starter relay
Old Oct 30, 2015 | 09:26 AM
300k's Avatar
1. battery cable
3. ignition switch
4. starter relay
Nice, and thanks, I'll be checking these things listed today.
Old Nov 1, 2015 | 11:05 PM
300k's Avatar
Everything Looks fine. Electronics seem to function normally. Is the GROUND wire supposed to have a huge open spot on the cable right before it bolts on the chassis like 4-5"? This wire is exposed and it looks super oxidized, corroded and whatever else 24 years does to an exposed wire.
Old Nov 2, 2015 | 04:48 PM
sr20paisa's Avatar
d15 hitting 9k LOL, mine came with a dohc zc it had a cover blocking the tensioner, the tensioner was the culprit in that situation
Old Nov 2, 2015 | 10:23 PM
300k's Avatar
That definitely sucks!
Old Nov 4, 2015 | 08:50 PM
300k's Avatar
Had a couple things from amzoan arrive today. One of them was a ground battery cable. Replaced that and low and behold crank and start?!?!? Started right up, killed it, started right up again, drove around, started right up, parked and sat, started right up again. I CANNOT believe the ground battery cable could just completely stop my motor from cranking!! Finally fixed.
No crank no starts always check the ground cable WTF. Thanks for the responses you guys nailed this one!
Sami0205
Engine Management and Tuning
Oct 29, 2016 11:58 AM
Sami0205
Oct 24, 2016 11:43 PM
texuslove
Jun 11, 2015 05:10 PM
BlueVxIDelSlo
12
Mar 20, 2011 05:37 AM
flip1199
Feb 21, 2005 03:52 PM
