Head corrosion...saveable? *with photos
Old Oct 26, 2015 | 05:41 PM
andoshan's Avatar
Default Head corrosion...saveable? *with photos
Hi all,
Long story short; I sprayed my cylinder head with heavy duty degreaser and looks like it fudged up my head(refer to photos below)...
Have any of you guys experienced a similar thing? Is it still "saveable"?
uggh
ewww
see all that white crap, cant be wiped it off... I have to pick up my pistons and rods this week so I'll also be getting advice from machine shop as well.
,Thanks for your input
Old Oct 26, 2015 | 05:45 PM
Tyler Dirden's Avatar
I am Jack's...
Default Re: Head corrosion...saveable? *with photos
Heavy duty degreaser AKA muratic acid?
Seen this before. For a normal build and a must save budget it is OK to use them just clean them very well on the machined surfaces with red scotchbrite pads. The entire machined surface is not altered but still usable. There are better cleaners suitable for aluminum and I bet you look into them for your next clean up.
Old Oct 26, 2015 | 05:55 PM
andoshan's Avatar
hey Tyler thanks for the input. I was using using kerosene prior to the degreaser, I should've just got another bottle of kero. I might just end up getting another head
Old Oct 26, 2015 | 06:38 PM
andoshan's Avatar
Update:
Soda blast ftw!!
before
after
Old Oct 26, 2015 | 06:46 PM
I am Jack's...
Very simple solution and doesn't change machined surfaces.
You still should run some red scotchbrite pads across the cam jouranals to get the surface extra smooth I think. Get the head resurfaced by a competent machine shop that can get the right finish too.
hmoob_thoj89
Mar 23, 2011 04:01 PM
WishinItWas
Aug 22, 2007 02:58 PM
RACEPAK
Jul 22, 2007 07:08 AM
ZXRider
Dec 10, 2006 03:13 PM
Rosko
Welding / Fabrication
Nov 26, 2006 08:19 PM
