Door Weatherstrip Removal?
Old Oct 25, 2015 | 03:54 PM
94_DX's Avatar
Default Door Weatherstrip Removal?
Am replacing my crunched passenger side doors on my 94 DX sedan with a pair I bought off CL. The new/used doors are missing the weather stripping so I need to carefully remove it off my old doors and reinstall it without destroying the small retaining clips found along the stripping that attach it to the door frame. Is there a special tool to release/remove the ? Something like a miniature version of one of those door panel clip removal tools? BTW - this is the main, thick weatherstripping that seals the doors when closed.
Old Oct 25, 2015 | 05:27 PM
Former User's Avatar
Default Re: Door Weatherstrip Removal?
https://honda-tech.com/honda-civic-d...ivics-3063334/
Old Oct 25, 2015 | 05:35 PM
94_DX's Avatar
Thanks but what I need is info pertaining to R&R'ing the thick weatherstripping that seals the entire door when closed, not the moulding/trim.
Old Oct 25, 2015 | 05:38 PM
The seal is very easy. Yank off door panel, remove glass and seal. Reverse order with new seal.
Old Oct 25, 2015 | 05:43 PM
94_DX's Avatar
I don't think we're on the same page, Ron. I'm talking about the weatherstrip that encircles the entire door and seals against the door frame when the door is closed, keeping dust/moisture out. I want to know how to remove it without damage and reinstall it again, if this is possible.
Old Oct 25, 2015 | 05:45 PM
Post pictures.
We're on the same page. It literally pulls right out. It's just tucked into a groove.
Add car information to your first post.
Old Oct 25, 2015 | 05:50 PM
tony_2018's Avatar
Fish Twig
He's talking about the rubber surrounding of the entire door, not the glass molding that you're referring to Ron.
OP, its kind of tedious and actually hard to explain on how to do this. Just be careful on not ripping it.
Oh, maybe you mean the inner weatherstrip?
Old Oct 25, 2015 | 05:56 PM
94_DX's Avatar
Thanks, Tony.
There seem to be tiny retaining posts that are set into the rubber seal on one side and fit/grip tightly into regularly spaced small holes in the door body around the entire seal. Looking for the best method to get them out without tearing them loose from the seal or damaging them so they don't hold when reinstalled.
Old Oct 25, 2015 | 05:58 PM
94_DX's Avatar
Yes, the Inner, Main WS. Thought I was making that clear.
Old Oct 25, 2015 | 05:59 PM
Best to always post pictures. Add car info to your first post - required.
Old Oct 25, 2015 | 06:17 PM
tony_2018's Avatar
Fish Twig
Pics, without them we would never get any eye candy.
Old Oct 25, 2015 | 06:40 PM
94_DX's Avatar
It's a 94 DX Sedan. Here's a photo of some of the retainer posts that were left in the doors I bought. Whoever took the weatherstripping from said doors evidently just yanked it off leaving the retainers in place.
Door showing old retainers still in place
Retainers removed
Old Oct 26, 2015 | 03:56 AM
tony_2018's Avatar
Fish Twig
So, its a rubber strip. Has tiny holes on side that touches the door frame. The retainers are the challenge. In order to remove it you would have to stretch the tiny hole to get one side of the retainer out and than slide the other end out. Do you get it?
Old Oct 26, 2015 | 07:56 AM
94_DX's Avatar
Yes, I get it
As I've said multiple times, it's the primary weatherstrip on the doors responsible for sealing out dust/moisture.
I assumed that someone here had to have removed/replaced/reinstalled the stuff in the past and knew the best way to do it without fu*king up the strip itself or the retainers up, if that's even possible. I can't afford to purchase new weatherstrip and my existing seems to be in good shape so I figured it should be reusable.
I guess I'll just stop by a Auto Body Repair place today and get the answers to my questions from them...
Old Oct 26, 2015 | 09:48 AM
tony_2018's Avatar
Fish Twig
Yes, I get it
I did and I gave you instructions on how I did it w/o ******* IT UP. You stretch the tiny hole as much as you can to detach it from the clip, one clip at a time. That is it.
Old Oct 26, 2015 | 10:58 AM
94_DX's Avatar
So you're saying you remove the weatherstrip, leaving the little retainers in place in the door then to reinstall you have to somehow get the head of the retainer back in that tiny hole on the backside of the strip? Did you actually do this successfully yourself or are you just saying you think this is how to do it?
Not being hard-headed here, just don't want to ruin my W-strip.
Old Oct 26, 2015 | 11:05 AM
Example -->
You need a new much more positive tone here. Just go talk to the repair shop and be done with it.
Old Oct 26, 2015 | 11:14 AM
94_DX's Avatar
Positive tone? WTFE I stated clearly what I was trying to do and the part I was working with. You post wrong info about the glass seals then bag on me?.
Old Oct 26, 2015 | 11:19 AM
Let your repair shop help you as your question has been answered. Also read the forum Rules sticky. If you have any questions, please PM me.
alex1321
12
Jan 25, 2013 08:59 PM
Nuts
Honda S2000
Aug 7, 2008 06:32 PM
todd.ludwig
May 1, 2006 02:27 AM
truckhigh
10
Jun 7, 2005 06:09 AM
Adampops
Aug 26, 2002 06:03 PM
