Hondata S300 question- OBDII and OBDI
Old Oct 23, 2015 | 10:02 AM
Ohmega's Avatar
Default Hondata S300 question- OBDII and OBDI
96' del Sol SI Manual trans.
USDM p28 OBDII ECU
Going to be boosted soon and I'm looking into the Hondata s300. Do i need an OBDI ecu for the Hondata? Or can I chip my OBDII and use an adapter.
No experience chipping ecu's- please be kind .
Old Oct 23, 2015 | 11:28 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Hondata S300 question- OBDII and OBDI
As stated on Hondata's own website, it must be a OBD-1 ECU. You will need the appropriate jumper conversion harness as well to go from an OBD-2 ECU to an OBD-1 ECU.
https://www.hondata.com/s300
Old Oct 23, 2015 | 11:45 AM
Ohmega's Avatar
Thank you for your response.
I read the whole Hondata site and that was what confused me. So I'm good to go as long as I have an OBDI ecu and the conversion harness, understood.
Close thread
Old Nov 4, 2015 | 09:11 AM
mtber's Avatar
Close thread
EFI Beginner Guide explains everything too :-)
Old Nov 4, 2015 | 10:16 AM
Ohmega's Avatar
Wow, that is a powerful resource. Thank you for sharing. After perusing that site, I think I'm going to order a s300 from there. Hopefully I can find an OBD1 P28 at the junk yard.
Old Nov 4, 2015 | 12:59 PM
spAdam's Avatar
Loved
Community Favorite
p28 OBDII
No such creature.
Old Nov 5, 2015 | 07:16 AM
Ohmega's Avatar
Not sure what you mean. I use "II" instead of the number "2". Looks better IMO, but I guess I SHOULD use "2"
Old Nov 5, 2015 | 08:53 AM
spAdam's Avatar
Loved
Community Favorite
No that's not the problem. The P28 is an obd1 ecu only. You either have a P28 or something obd2. Not both.
Old Nov 5, 2015 | 11:35 AM
Ohmega's Avatar
You're mistaken, the '96 del Sol SI (D16Y8) has an OBD2 P28. I'm telling you. There's a shroud of mystery whether or not P28's can be OBD2, but I assure you, I have an OBD2 P28.
Old Nov 5, 2015 | 01:08 PM
spAdam's Avatar
Loved
Community Favorite
You're correct. I missed the Del Sol part. It was an oddball with its own ecu.
Milab21
Engine Management and Tuning
Jan 14, 2009 06:18 PM
tub_sephiroth
Nov 18, 2004 10:27 PM
gunmetalcivic
May 22, 2004 08:33 PM
swlabhot
Nov 20, 2003 08:07 PM
integranator
Mar 2, 2003 09:45 AM
